Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #136 (permalink)
Old 04-23-2008, 01:24 AM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
I know ford has it on the 6.4L, just trying to figure out why they didn't use it from day one with the powerstrokes. Is it really that much more expencive? Its pretty much the standard all over the world with diesels from light duty cooper minis that get 60 MPG all the way up to HD hauler trucks.
I have my doubts that it cost 100k just for the common rai conversion, but its probably not cheap either. I'll be keeping my 6.9 for a while I think.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #137 (permalink)
Old 04-23-2008, 01:34 AM
Momorris Momorris is offline
Momorris is starting off with a positive reputation.
I agree, I wish Ford had caught on earlier, but it seems like they passed the competition with the 6.4 common rail technology.
As for 100k, that was probably for the whole truck. I should have been more specific, sorry.
__________________
2005 F250 KR CC 6.0L
DashDAQ - soon to be Phalanx Monitor
ARP headstuds
Silverline Turboback
SCT X3...Spartan and Innovative tunes
DFuser Coolant Filter
  #138 (permalink)
Old 04-23-2008, 02:04 AM
immastrokinnow's Avatar
immastrokinnow immastrokinnow is offline
immastrokinnow is starting off with a positive reputation.
i just wish they could make a deal with CAT. c'mon ford ceos. they would sell a ridiculous amount of them just because of the cat name....
__________________
1997 psd x-cab long bed 4x4. tymar intake and downpipe, fpr shim, bully dog chip (junk) 6 inch bullhauler stacks. coon 14.7k and trans mod.
On The Way. dp tuner, gauges, plow, d66, stage II injectors from jim...
  #139 (permalink)
Old 04-23-2008, 08:56 AM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Caterpillar uses HEUI and International engines except the 6.4 liter use HEUI, it sounds like they would be major exceptions to the "standard".
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #140 (permalink)
Old 04-23-2008, 06:45 PM
bookem15 bookem15 is offline
bookem15 is starting off with a positive reputation.
Quote:
Originally Posted by LaredoF350 View Post
My 6.0 puked some from quite new but it was long before head gasket changing was in fashion (so to speak). I couldnt get FORD to fix it but rather they took my old 6.o tune that had more power, got better fuel mileage, had a tow/haul that worked, and had the quiet idle with pilot injection without hesitation. I added a tuner and the bolts stretched enough to have the repair done on warranty without hesitation. Who screwed who through all of this? Am I bad for doing it? The last thread where I viewed my thoughts on this was locked.
Bookem, here is what you wrote in another 6.7 thread - you will have to be more consistent my friend - you question why I would do mods, then you say If more power is required, go to the aftermarket
yes I did state that in another post but where does it say that I was going to do it during the warranty period? I am just curious why people would junk the warranty to save money when if the motor breaks down the savings is gone plus a lot more. that is all
__________________
Drive it like ya stole it !!!
2004 F150 extra cab 4X4
85,000 miles 4" lift and level
Next truck
2011 F350 cc 4X4
  #141 (permalink)
Old 04-23-2008, 09:36 PM
LaredoF350's Avatar
LaredoF350 LaredoF350 is offline
LaredoF350 is gaining momentum as a positive member of FTE. LaredoF350 is gaining momentum as a positive member of FTE.
Because some of have built up a relationship with our dealers whereby some of the mods dont necessarily void warranty. Sometimes buying from the place with the cheapest price isnt the best value in the end! With a 5 year / 160000 km warranty on the engine, how many people will drive it that long before doing any mods if they were planning on doing them?
When I look at the performance that has been unleashed from the 6.0, there is no way I could ever drive one stock. Dont get me wrong, I dont have any high horsepower programs (just a STREET type of program for driving around and a TOW program for when I pull heavy). I also dont beleive in 'over-gearing' like some guys have done by adding huge tires and not making gear change compensations.
I look at the 6.4 as one heck of a platform on which to build. I would remove the DPF (but replace it with a 'dummy' look alike rather than a straight pipe), leave the CAT intact, and just put on a cat-back exhaust. Add a tuner from one of the custom tuners who have worked hard to gain a good reputation and enjoy the truck for what it should/could be.
I didnt post here to argue, just to make a point!
__________________
2008 F-250 Lariat SRW 4x4 CC SWB ...
... 6.4L & Torqshift w/3.73
... Dark Stone Metallic / Pueblo Gold
... Readylift levelling kit
... Toyo MT 35-12.5-18
BIG$HOW --«Õ¿Õ¬»
  #142 (permalink)
Old 04-24-2008, 08:08 PM
now that is a good one. I like the thought of making a dummy look alike and then putting a tune to it. We could make a case on that and maybe our service managers would honor the warranty work. Have you ever heard of anyone trying to make a dummy version? Also I was not trying to argue if that is the way it sounded I am sorry for that.
__________________
Next truck
2011 F350 cc 4X4
  #143 (permalink)
Old 04-26-2008, 02:45 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
Quote:
Cat engines actually are very similar in ways to international's heui's system.
Nothing but hype. Anyone running cat engines will want cummins. Cummins owners want cats. I-6 cummins owners think fords v8 diesl is the cats meow. Ford owners think the cummins is spectacular.
HEUI 7.3 PSD's has it's downfalls, but so does 5.9 cummins. Cat and international didnt use HEUI to make life miserable, its supposed to reduce cost of ownership.
I read a cost comparison lately of the big 3 cost of ownership:
Chev: Lowest.
Ford: second lowest.
Dodge: highest.
Heres the thing....
% spent towing:
Ford : highest
Dodge : second highest
Chev : lowest.
So, truth be told, i'll agree the cummins is a great engine, but it's not a miracle under the hood like people think.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #144 (permalink)
Old 04-26-2008, 07:24 AM
firehawk198's Avatar
firehawk198 firehawk198 is offline
firehawk198 is starting off with a positive reputation.
Just curious where you read the comparison?
__________________
http://www.ford-trucks.com/user_gall...photoid=1645522008 F450 4x4 4.30's Dark Toreador red delivery 4-05-07 13.46 mpg mty 8.64mpg towing 16,950# over 4,800 miles
99 F350 V10 DRW 3.73's 5 speed stick traded 11.5mpg
1995 Firehawk 315hp 6 speed 06 Escape 22mpg
93 40th Anv. Vette, 2006 Armada, Kountry Star 5'th wheel 40'
  #145 (permalink)
Old 04-26-2008, 09:32 AM
Powerstroker099 Powerstroker099 is offline
Powerstroker099 is starting off with a positive reputation.
6.7 possibility
Has anyone else heard the rumor that Volvo will be the engine of choice for the new diesels both F-150 and the Super Dutys?
  #146 (permalink)
Old 04-26-2008, 09:51 PM
David85's Avatar
The diesel engine is over a century old by now. Its not cutting edge technology even with all High tech life support systems that are integrated in them these days. Its still just a rattle-box for pete's sake.
Any one of the companies mentioned here in this discussion is capable of making the best diesel ever made. All thats needed is the will to make it happen.
One thing I will say about the cummins, is that it has remained a a cummins since 1989 when dodge first offered it. Instead of making a completely new engine every 5 years with a new market spin, cummins simply upgraded their engine to keep pace with the times. I respect that, even if there were still problems with the computer controlled versions when they came out.
I have a hard time respecting ford when you consider how many diesel engines they went through in the last 20 years. Just pick one and stick with it!!
Even the old 6.9 is capable of 300+ Hp with an intercooled turbo setup. but instead they made an entire new engine just to get a turbo on it, not intending to bash the powerstroke series, but really, whats the point?
__________________
  #147 (permalink)
Old 04-26-2008, 10:44 PM
parkland's Avatar
Quote:
A compilation a friend did; he had to work hard to get that information, theres lots of good websites to get charts and numbers from, but you have to do quite a bit of work to find out figures like i stated.
Those figures were across 16 random states, and 2 provinces i believe.
I was actually supprised, every state and province told the same story (in figures), i wasnt expecting that at all.
This work he did only included cost of ownership, and pulling duty.
You could also cross reference "customer satisfaction", and other variables into the mix as well, but I doubt that dodge will win more in any other categories, i could be wrong though.
Yes, a cummins in a ford would probably take 1st prize every time, but like i said before, they only come in dodges.
__________________
  #148 (permalink)
Old 04-27-2008, 03:05 PM
Quote:
Originally Posted by Momorris View Post
I will take crappy exhaust and common rail injection over a good exhaust and the HEUI setup.
Technically, HEUI is common rail injection.
__________________
one EGR valve.
  #149 (permalink)
Old 05-03-2008, 01:44 AM
lazyscholar lazyscholar is offline
lazyscholar is starting off with a positive reputation.
Im very excited about a ford in house diesel. The only problem i can think of is milage. Don't get me wrong 400 hp 700 lb/ft torque is definately something to brag about but if it gets under 18 mpg it isnt worth it. Why not make a truck that can pull anything you need it too and get good mpgs seems to me people would jump on that.
  #150 (permalink)
Old 05-20-2008, 11:20 AM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
Even at $4.XX a gallon I still have the same argument on fuel mileage- I didn't buy my PSDs to get good mileage, I bought them to pull trailers. If my #1 concern was mileage I would've bought a ranger, or better yet, a moped. I want to see ford finally settle down with a reliable diesel (a trend which ended with the arrival of the 6.0L in my opinion) and STICK WITH IT. I don't care who makes the darn thing.
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
Proud to be an OHIO BOY
Tags
2010 , 250 , 4x4 , 67 , accessories , aftermarket , boss , dc1 , diesel , eng , f250 , foerd , ford , frod , rord , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
