I dont have that, I only have a Switch (push) with 2 wires, and is to use it, when you are working alone and you are under the hood (engine compartment)or under the vehicle and you need that the motor spins for instance to locate the drain plug of the torque converter or to empty the cylinders of oil and not to get hidrolock, OK?. Do you know what I mean?
Use that switch on the starter solenoid on the fender well. Clip one end on the big post coming from the battery and the other on the small wire R/LB (red w/ light blue tracer).
FYI: Do not hook up to both large wires, that will make your "remote switch" heat-up & melt.
