How do i make my truck quieter in the cab
how much work do you want to do ? remove the seats and carpet and install a sound barrier like B-Quiet directly to the metal.. it will deaden it a lot .. http://www.b-quiet.com/index.html
Jason,
You have a 5" strait pipe. ie. no muffler. If you want the noise, enjoy the noise. If you just want other people to hear it than get some amps and big speakers and broadcast the sound of a diesel truck....
Not meaning any offense but wanting others to hear your noise and not wanting to hear it yourself sounds a bit off. Reminds me of those tuners who blast the stereo while they are inside paying for gas..
There should be a thick piece of rubber gasket along the bottom of your door, right below where the whole door trim stops and the painted sheetmetal starts. You can easily see it when you open the door.
If you don't have the gasket, you should see about 6 holes, spaced about 4 inches apart, that is where the screws go in to hold the gasket.
I don't know how much soundproofing it does, but it does alot of waterproofing. If you don't have that strip you are probably getting alot of dust/must on the inside of your door when driving in the rain.
