Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-26-2007, 10:56 AM
willyswrecking willyswrecking is offline
Garage is empty, add now
willyswrecking is starting off with a positive reputation.
Question Stuck Valves
I was finally back to work on my '49 F2 226 this weekend. I have the head off to replace a broken valve. I found that I have to intake valves that are stuck also. I tried lubricating them with Liquid Wrench and I have them free, but not moving freely. My question is, do I have to replace the guides, or is there something I can do like ream them? I don't want to pull the engine, and I know that tool for removing the guides is pretty long. Probably too long to use with the engine in the truck. Does anyone have some suggestions for me??? Thanks
  #2 (permalink)
Old 03-26-2007, 01:11 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Lubricate them with a bit of kerosene and they will come loose. For years after the second world war cars were brought out of storage with stuck valves and the old mechanics ran kerosene thru the carburators to free them. You knew when the activity was going on clouds of white smoke, but it worked.
  #3 (permalink)
Old 03-28-2007, 02:57 PM
mattg mattg is offline
mattg is starting off with a positive reputation.
If you have a valve that will shut after you give it a tap then it will start to work on it's own after you run it. Try some Berrymans Chemtool in it too once you get it running. We had the very same problem in a 51 F100. Didn't take long at all. Also we just finished a flathead in a 35 sedan that was full of rust and debris in the cylinders. We just needed it to run so we could move the car around on it's own. So we ran a hone through the cylinders real quick, got all of the valves working but one intake. It wouldn't always close on it's own, you had to give it one or two light taps and then it would shut. We figured it probably would free its self after we started it and ran it for awhile. It smoked and ran rough at first but after time it actually ran really nice. My point is that these motors are really tough. Get that valve lubed up as best you can like kotzy said, put it together and try it!
__________________
1996 F250 XLT Crew Cab Short Bed, 7.3L PS Auto Trans with 285/75 R16 A/Ts. 240,000 miles and no sign of stopping!
Tony Wildman 4 position TS chip
Stage 1 Injectors
6637 filter Mod
3" downpipe, Cat Delete, and 4" out the back
Tags
300, 49, 6l, cylinder, f150, flathead, ford, free, intake, stuck, truck, v8, valve, valves, vlaves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
