Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-25-2007, 09:39 PM
mrautocar mrautocar is offline
Garage is empty, add now
mrautocar is starting off with a positive reputation.
477-534 swap?
Hi. i have a 76 f 600 crew cab ramp truck with a 4 speed and straight speed rear. Its has a worn out 370 2v. I located a 477 or 534 engine in a 72-74 dump truck with a 5 speed trans and a 2 speed rear. i plan on using the entire drive line but unsure of the engine. Are these engines any good. are ther better alts to these. thanks
  #2 (permalink)
Old 03-25-2007, 11:20 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
I think you can upgrade to the 429, same family as the 370. That would be your best bet, unless you want to upgrade to a diesel, in which case the Cummins 5.9 is probably the most available usable engine for your application.
These old engines are not what you'd think for power, and are very thirsty.
  #3 (permalink)
Old 03-26-2007, 06:09 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is gaining momentum as a positive member of FTE.
Talking
85E is right a 429 is a much better choice, that was the replacement for
the old SD engines. The difference between a 370 and a 429 is a lot. A
460 can be swapped for a 370 but it takes more work, 429 is a bolt in.
Have A Good Day---------Hotwrench
__________________
FERGUSON'S GARAGE est. 1967
car , truck , heavy equiptment repairs
4 X 4 specialists PORTABLE WELDING SERVICE
TOWING New @ used PARTS
1981 L 800 460 5 speed , 2 speed rear
1957 F 600 390 5 speed
  #4 (permalink)
Old 04-05-2007, 07:29 AM
Kurn Kurn is offline
Kurn is starting off with a positive reputation.
I'd use the 429 also.You'll get a lot better performance than with the SD engines,and it's a bolt in,and parts are available.
Tags
477, 534, difference, ford, speed, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
