Distributor install question
I just put in a new distributor in my 87 with an 302. I have done this before on different vehicles but it doesnt want to start. What I did was I put #1 at TDC, then pointed installed the dist. and pointed the rotor toward #1. I noticed that on the dist. cap the plug terminal marked #1 is on the opposite side of the cap. should the rotor face the #1 terminal on the cap? or point toward the #1 cylinder?
I just tried that, it still didnt kick over, I think I may not have it on the compression stroke. I heard hissing as my TDC indicator was moving up, so I thought it was. I did forget to take the TDC indicator out and put the spark plug back in. It sounded like a 44 Magnum going off. It didnt break it though, haha
it doesnt matter
it doesnt matter where you put the number one plug wire on the cap its not magic they put it there so you dont mess it up when your workin on it the next time wherever you put the number one plug MARK IT SO YOU DONT FORGET WHERE IT IS unless you like pullin the dizzy me I could do with out it feelin around for the oil pump drive is a pain on mine good luck
clrose99
04-12-2020 11:17 AM
gysgtbigdaddy
08-19-2013 11:14 PM
Lakerat
02-16-2011 10:42 AM
LeatherNuts
12-09-2004 11:38 AM
