Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-25-2007, 05:34 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CUSS
1989 Ford Ranger
Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation
DICOR Roofing Materials - Straight from the horses mouth...
(Er, ehm, sorry about that Horsepuller... )
www.dicor.com
It takes some surfing around at their site, but a lot of stuff that I MYSELF was not aware of is there, with product descriptions. The LAP JOINT SEALER for EPDM roofs is my target, and what we need is a source to order it from without going through a middle man (such as an RV Dealership. ANYTHING bought at a Dealership has a considerable markup!).
Your ball - let's see what we can find.
The Lap Joint Sealer is found under roofing maintenance. It is the same we use at the dealerships. Except that it comes in different colors...
Even at three and a half bucks a tube, if you can apply it yourself -you'll be better off than shelling $200 or more for a roof re-seal. The average roof takes about ten tubes - GO FIGURE!
~Wolf
PS: Last time I looked, caulk guns were $1.99 at LOWES
__________________
2009 FTE Online CHAMPIONSHIP
FINAL ROUND of COMPETITION
  #2 (permalink)
Old 08-08-2007, 10:03 AM
unregistered guest unregistered guest is offline
unregistered guest is gaining momentum as a positive member of FTE.
http://www.eternabond.com/
This is what I just used to replace my lap sealant. You can apply it right over the lap sealant. It's more expensive yes. I found it online for $60 a roll. But once you do it once it's done forever. I think rv manuafacturers should put this on at the factory. No more worries about a leak in my rubber roof now.
  #3 (permalink)
Old 08-11-2007, 02:05 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
You can by EPDM lap sealant at most roofing supply houses, but as a walk in you will probably pay $4-$5 / tube. Most will stock black, some will have white also. They will also have urethane caulk you could use. The eternabond is an excellent product also.
As for sealing any seam joint movement will be your enemy, and surface prep (cleaning) is extremely important.
  #4 (permalink)
Old 08-11-2007, 05:40 PM
mike93 mike93 is offline
mike93 is starting off with a positive reputation.
Try here -
Best Materials Roof Repair
EPDM Roof Coatings
Mike
__________________
Mike93
'90 F150 4x4 XLT
5.0 E40D
"76 F250 Highboy
w/390 & 4spd
  #5 (permalink)
Old 05-27-2009, 07:23 AM
quick83 quick83 is offline
quick83 is starting off with a positive reputation.
I have contacted alfa systems the company that manufactures the EDPM roof material and they told me to only use the 2 products they reccomnd.(anything else voids the waretee)One is made by them, ita a glue like primer and then 2 coats of the rubber paint. You have to put the 1st coat of paint on within 20-30 min b 4 the primer dries. I figure they are the one who made the roof they should know how to treat it. They also said its normal for black to show after 10 years with no cover put on the rv.and to just re-coat it.
  #6 (permalink)
Old 05-27-2009, 06:26 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
The majority of rubber roofed trailers and RV's are EPDM. If ALFA has their own product now - you are definitely stuck with what they recommend. At this point I suggest anyone with an ALFA coach check that out.
I also heard recently that ALFA has gone into bankruptcy - but I have no details on that.
__________________
Tags
5th , alfa , dicor , joint , lap , primer , reseal , roof , roofing , rubber , rv , sealant , seams , systems , target , trailers , wheels , wwwdicorcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
