"rebuild kits" for 9in rear end
Has anyone used a Ratech general rebuild kit (crush sleeve, gasket, pinion seal) to rebuild their 9 in rear end? I recently found a 28 spline out of an early 80's F150 for $40!!! Can anyone recommend what they have used (I have seen them also in LMC Truck)?? Thanks for the info!!
Ryan
Ryan
Genuine Ford Parts (1980/ Ford 9" list # 88)
1-E3TZ-4036-B .. Gasket
1-B7AZ-4211-A .. Pinion Shaft
1-C9AZ-4215-A .. Pinion Gear Kit (gears & washers)
2-C9AZ-4221-A .. Differential Bearings (Industry # LM102949)
2-C9AZ-4222-A .. Differential Race (Industry # LM102910)
2-C8OZ-4236-A .. Axle Gear
2-B7A-4616-A .. Pinion Race (Industry # M88010)
2-B7A-4621-A .. Pinion Bearing (Industry # M88048)
1-C2AZ-4625-A .. Pilot Bearing (Industry # R1535 TAV)
1-B7AZ-4627-A .. Pilot Bearing Retainer
1-B7A-4662-A .. Crush Sleeve
1-B7A-4669-A .. "O" Ring
1-E2TZ-4676-A .. Pinion Seal - 1980/83
or
1-E5DZ-4676-A Pinion Seal -1984/
or
I got a rebuild kit on Ebay that had all Timken bearings for less than $80 to my door just like this one HERE . I'll also make my usual shameless plug for the rebuilding your 9 inch rear end DVD from Ken Collins at Badshoe productions. Tremendous video, which can make anyone an expert.
EDIT: Whoever you order the kit from, I would recommend buying an extra crush sleeve. I over crushed my 1st one and no one in town carried them so I had to mail order a replacement. They're only about 3 bucks, but it shut me down for 4 days waiting for them to arrive.
Don't forget you'll also probably want new axle shaft bearings and seals as well.
Number Dummy: Thanks for the part #'s...these are handy at O'Reallys (Oreilly's)...those guys take 2-3 times to get it right!!!
Goobzilla: I took a look at the demo video...it is dumbed down perfectly for me!!! I have heard about getting a second crush sleeve for that reason exactly...
Thanks for the info!!!!! I will look into each a little further!!!
Ryan
Ryan
Mister_King
11-25-2014 08:06 AM
