Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-04-2008, 04:41 PM
Dan7378 Dan7378 is offline
Dan7378 is starting off with a positive reputation.
When u flip the 5 way over and plug it back in then turn your headlights on that puts power to the solenoid on the mastercylinder that keeps the brakes from locking up. Next time u look at a 5 way flat and 4 way flat hold them next to each other u will see what I mean.
I wouldn't recommend doing this as permanent just something I used to do for people who were renting or borrowing trailers and only had a 4 way.
If u got a 7 way u just buy an adapter.
__________________
78 F-150 4X4 reg.cab,long bed,400,NP435,NP205,Ford 9 inch,Dana44
74 F-100 4x4 reg.cab,long bed 360 NP435,Dana21 Ford 9 inch w/ locker,Dana 44,4.10
86 F-250 4x4 reg.cab,long bed 460,T-18,8-inch subwoofers w/200 watt amp,K&N air filter,4.10
  #17 (permalink)
Old 02-06-2009, 08:57 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CUSS
1989 Ford Ranger
Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation
HOUSTON - WE HAVE A PROBLEM....
The diagrams are gone.
__________________
2009 FTE Online CHAMPIONSHIP
(located in the General Automotive Forum)
ROUND TEN POLL
  #18 (permalink)
Old 03-29-2009, 09:20 PM
MillerKing MillerKing is offline
MillerKing is starting off with a positive reputation.
Eternabond still performing well?
Looked at the Eternabond site, looks like good stuff to me... Just had a skylight put in a year ago and the Dicor lap sealant has already begun to fail by cracking. Lap sealant was dealer installed I might add...
  #19 (permalink)
Old 05-02-2009, 04:40 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Here is something that I came up with a while back.
RECLINER HOLD DOWNS
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #20 (permalink)
Old 05-02-2009, 06:13 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
Quote:
Originally Posted by Kwikkordead View Post
THAT one is ingenious in it's rare simplicity, low-cost installation and parts, and prospect of long lasting service. It is also the best thing I have ever seen as far as immobilising chairs in transit
Well concieved and well done. I imagine if countersunk padeyes are used it only takes a few minutes with a small wood chisel through a slit in the carpet to make them level with the floor - but the carpet and padding and the right padeyes should eliminate the need.
__________________
ROUND TEN POLL
  #21 (permalink)
Old 05-03-2009, 10:50 AM
Jesus spoke a lot
1999 Ford F-550
You don't need to cut out the carpeting at all. Just use screws long enough to reach down through the carpet padding and tighten it all down.
The padding will compress down to the point where the loops are level with the carpet.
__________________
Dan
God and Dog
  #22 (permalink)
Old 05-06-2009, 03:48 PM
n4aof's Avatar
n4aof n4aof is offline
n4aof is starting off with a positive reputation.
Quote:
Originally Posted by Dan7378 View Post
If your towing a boat trailer that has hydraulic brakes and has the 5 way flat plug you can tow this w/ your truck if u have a 4 way flat except.....when u want to back up get out of the truck walk to the back and pull the plugs apart flip the trailer plug over and plug it back in then turn your headlights on.
Flipping the plug over puts the brake wire that keeps the brakes from locking up plugged into your taillights and by turning your lights on your putting power to it just remeber when u start to go forward again to flip it back over.
But where do you get the ground connection - the only ground would be through the hitch & ball.
  #23 (permalink)
Old 08-23-2009, 08:41 PM
wb6anp wb6anp is offline
wb6anp is starting off with a positive reputation.
For any Rv here is a reason to have a surge suppressor if you don't already have one. I have a hardwired version so it won't get stolen.
Also another nice video on rv electrical systems. Especially part 1. having to do with surge protection.
http://www.progressiveindustries.net/video.htm
__________________
2009 F-150 Supercrew Platinum in Dark Blue Pearl
2008 Escape Hybrid
2008 Tiffin Allegro 32BA Motorhome on a Ford F-53 6.8l V10
http://community.webshots.com/user/wb6anp
  #24 (permalink)
Old 08-23-2009, 08:48 PM
Another tech library
Here ia a link to the tech Library on an rv site that I am a member of, a lot contains info fro Motorhomes but a lot also can pertain to most rv's.
http://rvtechlibrary.com/contents.htm
__________________
2008 Escape Hybrid
  #25 (permalink)
Old 09-03-2009, 01:15 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE.
Reps to you Greywolf. Thanks for the help.
__________________
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD
2000 Ranger 4X4 No MODS, yet!
  #26 (permalink)
Old 09-03-2009, 01:34 PM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
My Tech Tip
My tip deals with the comode... It is a pain to keep the tank clean, but with this procedure I use, and have been telling people for a few years now, it works great...
I put a bag of ice down my commode, when I am done camping, but on my way to the dump station. The ice breaks up the clumps that are stuck, and melts into water for easy dumping... I also use this, at the end of the year, I put a bag of ice down the commode, then drive to the camper place, do give my tank a final dump... It reduces alot of the odor, when dumping, and when flushing...and I dont need a stick to clear any clogs, as they are eliminated...
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
41 Plymouth 49 dodge flathead6 elec ign.
Sig Sauer P229 Two tone.
  #27 (permalink)
Old 09-03-2009, 06:55 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
ICING THE TANK is an excellent goody that has worked for many years. It's needed when people allow a trickle to run out instead of letting the tank fill and WOOSH it all out at once. Typically an RV is used as a domicile, and the user takes the easy way out - but you can't just leave the slice valve open all the time. That is the usual cause of "SOLID BUILD UP". It doesn't work the same as an installed house sewage system with three or four inch piping down to the main - the flat bottom of the tank allows things to come to rest, and they build up over time. The flush system on RV toilets does not use the same amount of water as a house toilet either - it is a bare trickle compared to the five gallons or so that rush down the pipes in a home system. (You can only carry so much water. The idea is not to waste it if you can help it)
Consequently, stuff piles up where it lays (to put it as delicately as possible) and will build up over time. You don't want that! Eventually there is a mound in there that has to be broken up by some means. Think in terms of dirt, or mud...
The tank needs to be scrubbed by SOMETHING, and Ice works well, because while it is hard as gravel at first - it will eventually melt. So nothing at all is left behind. It also has much the same "SPECIFIC GRAVITY" as water, so it doesn't just float on top of the water, it will scrub the bottom too.
I once found an old canteen and was told to fill it with nuts and bolts and water, then shake it as much as I could stand to get all of the old rust out. "ICING THE TANK" is the same principle....
__________________
ROUND TEN POLL
Tags
1989 , a4 , allegro , audi , boat , dicor , jetta , lap , motorhome , rv , schematics , sealant , seattle , tiffin , towing , volkswagen , wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
