1978 - 1996 Big Bronco
ARRRGH!! Can't--turn--ignition--key!!!
Old 03-24-2007, 07:06 PM
54Guy's Avatar
54Guy
54Guy is offline
Unhappy ARRRGH!! Can't--turn--ignition--key!!!
OR - BARELY can turn ignition key! '89 Bronco w auto trans. I replaced the key cylinder a while back thinking that would help fix this problem but it didn't and just keep slowly getting worse, now after about a year we can hardly turn the key at all! Anyone know what to do? Someone told me that they thnk there's some sort of gears in there that need to be greased, someone else told me that you have to replace the gears wherever they are, and it's a PITA job to do, but so far that's all I know about it. I'm reluctant to tear apart the steering column without knowing what I'm looking for. Can you help? Thanks!
Old 03-24-2007, 07:34 PM
ReAX's Avatar
ReAX
ReAX is offline
My 89 f150 went through several of the E315 (first or last of the part number) thingy. It's job is to make the circular motion of the loc cylinder in to a forward and reverse movement to work the ignition switch.
It is a pain the first three times, after that, I was going to put in a push button.
Old 03-25-2007, 01:25 AM
Maddognv's Avatar
Maddognv
Maddognv is offline
Ignition switch?
Check the ignition switch on lower steering column.There's a rod that run's from the lock to the switch. The switch may be loose, worn out or the rod may be bent. If your not sure want to do, Chilton's Truck Manual, 88-92, has a good descripion of what to do. Good Luck.
Old 03-25-2007, 10:11 PM
ag30265's Avatar
ag30265
ag30265 is offline
Go here. I just did this.
http://chrisb.users.superford.org/Br...ng_Column.html
Your problem could be the gear at the bottom of the cylinder,the slide that the gear engages with, the rod actuator(this is what broke on mine), the rod,or the switch at the bottom of the column.
As for the permanent fix- I've heard many people say that the push button start is the way to go. I myself have only had to replace the key tumbler twice and the ign. switch at the bottom of the column three times. The most recent repair(rod actuator) was due to me breaking it, not it breaking on me. Since I was in the steering column so deeply at the time of repair I went ahead and replaced my ign. switch and tumbler again. I regreased everything in the column and checked all the parts while I was there.
I don't see the need in converting my truck to push button start when I've only been in the column six times in 20 years. That's pretty good service life for a light duty vehicle IMO.
Do what you want to do to fix your problem. The link was given to me when I asked about the interior of the column last week. That topic thread is here.
https://www.ford-trucks.com/forums/5...ng-column.html
Good luck.
Old 03-25-2007, 10:51 PM
ReAX's Avatar
ReAX
ReAX is offline
Yep, that was the beast. I am very happy I was able to forget that part number/job.
BillC1009
08-12-2012 07:53 PM
BDFD
08-11-2010 10:17 PM
the Goat
01-05-2006 08:21 AM
kelouise
06-19-2003 10:56 PM
bowwow
06-01-2002 08:32 PM
Quick Reply: ARRRGH!! Can't--turn--ignition--key!!!
