dodge rims will fit my ford? - Ford Truck Enthusiasts Forums
Old 03-24-2007, 05:02 PM
fordinmudd's Avatar
fordinmudd fordinmudd is offline
fordinmudd is starting off with a positive reputation.
I can get a good deal on some real nice rock crawling rims but there off a 99 dodge 2500.would those fit my 96 f 250?im not sure.
Old 03-24-2007, 10:23 PM
cdrmotorsports's Avatar
cdrmotorsports cdrmotorsports is offline
cdrmotorsports has a good reputation on FTE.cdrmotorsports has a good reputation on FTE.cdrmotorsports has a good reputation on FTE.
I'm not 100% sure, but if I had to guess I would say they won't fit your truck. I've been wrong before!
Old 03-24-2007, 11:12 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
No the 99 dodge should have a metric pattern, and I think your truck is an inch pattern.
Old 03-25-2007, 12:11 AM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
they WILL fit
for future reference...
DODGE
YEAR MODEL BOLT PATTERN LUG NUT SIZE
87-90 DAKOTA 2-4WD 5 on 4.5 in. 1/2
91-04 DAKOTA 2-4WD 6 on 4.5 in. 1/2
98-03 DURANGO 2-4WD 6 on 4.5 in. 1/2
74-84 RAM 1500 2WD 5 on 4.5 in. 1/2
85-01 RAM 1500 2WD 5 on 5.5 in. 1/2
74-80 RAM 4WD W/O HUBS 5 on 4.5 in. 1/2
80-93 RAM 4WD W/HUBS 5 on 5.5 in. 1/2
94-01 RAM 1500 4WD 5 on 5.5 in. 1/2
02-04 RAM 1500 (NEW BODY) 2/4WD 5 on 5.5 in. 9/16
46-81 3/4-1 TON 2WD 8 on 6.5 in. 1/2
82-93 3/4-1 TON 4WD 8 on 6.5 in. 1/2
94-04 RAM 2500-3500 2/4WD 8 on 6.5 in. 9/16
FORD
03-04 EXPEDITION 2-4WD 6 on 135 mm 14X2.00
03-04 NAVIGATOR 2-4WD 6 on 135 mm 14X2.00
00-02 EXPEDITION 2-4WD 5 on 135 mm 14X2.00
00-02 NAVI / BLKWD 2-4WD 5 on 135 mm 14X2.00
97-99 EXPEDITION 2-4WD 5 on 135 mm 12X1.75
97-99 NAVIGATOR 2-4WD 5 on 135 mm 12X1.75
83-97 RANGER / BRONCO II 4WD 5 on 4.5 in. 1/2
98-04 RANGER 4WD 5 on 4.5 in. 1/2
01-04 SPORT TRAC 2/4WD 5 on 4.5 in. 1/2
83-04 RANGER / BRONCO II / EXPLORER 2WD 5 on 4.5 in. 1/2
90-94 EXPLORER 4WD 5 on 4.5 in. 1/2
95-04 EXPLORER 4WD 5 on 4.5 in. 1/2
49-96 ALL 1/2 PICKUP 4WD 5 on 5.5 in. 1/2
49-96 ALL 1/2 PICKUP 2WD 5 on 5.5 in. 1/2
66-96 FULL SIZE BRONCO 5 on 5.5 in. 1/2
97-99 F-150 PICKUP 2-4WD 5 on 135 mm 12X1.75
00-04 F-150 PICKUP (HERITAGE) 2-4WD 5 on 135 mm 14X2.00
2004 F-150 PICKUP (NEW BODY) 2-4WD 6 on 135 mm 14X2.00
97-99 F-250 LT DUTY 2-4WD 7 on 150 mm 12X1.75
55-79 F-250 / F-350 4WD 8 on 6.5 in. 9/16 OR 1/2"
55-79 F-250 / F-350 2WD 8 on 6.5 in. 9/16 OR 1/2"
80-98 F-250 / F-350 (OLD BODY) 4WD 8 on 6.5 in. 9/16
80-98 F-250 / F-350 (OLD BODY) 2WD 8 on 6.5 in. 9/16
03-04 F-250 / F-350 / EXCURSION 4WD 8 on 170 mm 14X1.50
03-04 F-250 / F-350 / EXCURSION 2WD 8 on 170 mm 14X1.50
99-02 F-250 / F-350 / EXCURSION 4WD 8 on 170 mm 14X2.00
99-02 F-250 / F-350 / EXCURSION 2WD 8 on 170 mm 14X2.00
-cutts-
Old 03-25-2007, 02:15 PM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
Like fishy said, they will fit, b/c both have 8x6.5" Bolt Pattern. Even older model chevy 3/4 and 1 tons have the same BP
Just like the older model dodges, 73-96 Ford 1/2 tons, Jeep CJs, and I want to say one more all have the same bolt pattern of 5x5.5
Old 03-26-2007, 12:19 AM
unrulee's Avatar
unrulee unrulee is offline
unrulee is gaining momentum as a positive member of FTE.unrulee is gaining momentum as a positive member of FTE.
I see that the bolt pattern is correct, but doesn't Dodge run very little back spacing?
Old 03-26-2007, 09:44 PM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.brokebronco is gaining momentum as a positive member of FTE.
Don't forget the center hole. It varies between manufacturers and Ford likes the big center hole.
Old 04-01-2011, 04:38 PM
mowpar mowpar is offline
mowpar is starting off with a positive reputation.
fishman chart
the chart you posted does not specify, what inch tires are involved, I would like to find a rim for my 93 f150,, that is bigger than 15 inches with the 5x5.5 bolt pattern 18 inches would be a nice size
Old 04-01-2011, 06:04 PM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
Considering his chart is 4 years old, I'm sure things have changed/been confirmed by now. But thanks for taying on top of it Captain O.
Old 04-01-2011, 06:07 PM
300/6 Freak 300/6 Freak is offline
300/6 Freak is starting off with a positive reputation.
yes the dodge rims wil fit. dodge and chevy and ford all have 8x6.5 untill 1999 when ford only switched to 8x170mm. The hub hole is just fine as Chevy rims (IE H2 rims) have a smaller hub hole and need to be bored out.
Old 04-01-2011, 11:54 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
Quote:
i was gonna flame you, but lost interest.
Will dodge or chevy rims fit on my 350? 2006powerstroke90 6.0L Power Stroke Diesel 5 04-17-2011 10:34 PM
Other wheels for F250 WMNY 1999 to 2016 Super Duty 2 11-08-2010 04:49 AM
will rims from a 96 dodge fit 96 250? fordinmudd Offroad & 4x4 4 12-30-2008 10:47 PM
What Year Dodge Rims Fit My Ford? hatchet Offroad & 4x4 9 09-07-2007 11:46 PM
Will Dodge Rims fit my truck?? nightskyisme 1999 to 2016 Super Duty 14 07-24-2007 09:09 AM
Tags
03, 1500, 1986, 1994, 2500, 5x55, 99, dodge, f150, f250, fit, ford, rims, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
