2006 F250 Integrated Brake Controller - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-23-2007, 04:57 PM
ron9florida ron9florida is offline
ron9florida is starting off with a positive reputation.
Question 2006 F250 Integrated Brake Controller
Where can I find troubleshooting info peculiar to this system? Will take to dealer asap but I would like to check basics until I can get it scheduled. The on-dash manual control works great (applies trailer brakes) indicating wiring and connectors are OK. But when the brake pedal is applied the trailer brake lights work but no voltage to brakes. All the fuses I have found marked trailer brake check OK.
Any tips or info will be appreciated. Thanks.
Old 03-23-2007, 05:05 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Did you go through the process of setting the gain? The steps are in the owner's guide.
Old 03-23-2007, 06:49 PM
Yes. I also measured voltage at connector. With the gain set at "10" for test purposes I measure 12 volts at the connector when using the manual control. When I have someone press the brake I measure 1 volt. It seems like a bad controller but I don't have a schematic or tech data other than the owner's manual.
Old 03-23-2007, 07:01 PM
I just found the following at etrailer.com. If I have a proportional (pendulum controller) then I guess I have jumped the gun in my ignorance.
" Proportional Pendulum Style Controllers are "enabled" by the brake pedal switch and "activated" by a Pendulum Circuit that senses the vehicle's stopping motion and applies a proportional voltage to the trailer's brakes. When properly adjusted the trailer will decelerate at the same speed as the tow vehicle. This increases braking efficiency and reduces brake wear."
Thank you for your input which helped get my brain in gear.
Old 03-23-2007, 08:36 PM
Back at square one. Controller has proportional output based on vehicle brake pressure. I get only 1 volt with heavy pedal pressure. My guess is bad controller or bad pressure sensor on master cylinder unless someone can give a more educated response. Thanks
Old 03-23-2007, 10:19 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Actually, there's always been a hoopla about the integrated controller not working unless the vehicle is travelling 15 mph or more, and of course this upsets 5th wheelers who want to test the integrity of their hook up.
Supposedly this was fixed in about March? '05, but who knows, maybe you got an old one nonetheless.
Maybe you could run a couple of test wires from the trailer brakes back to a VOM in the truck, then take a reading while braking at about 25 mph.
Another thing occurs to me as well. Does your controller turn green when the truck powers up? If it is still red the electronics are finding your trailer at all, and won't apply any braking voltage.
Old 03-23-2007, 10:22 PM
That should read:
Another thing occurs to me as well. Does your controller turn green when the truck powers up? If it is still red the electronics AREN'T finding your trailer at all, and won't apply any braking voltage.
Old 03-24-2007, 07:12 AM
rmosso1 rmosso1 is offline
rmosso1 has a good reputation on FTE.rmosso1 has a good reputation on FTE.
I have the old controller on my pre March 2005 build date F - 350. As such, the brakes do not work unless you are moving 15 mph + -. To check if that is the controller you have, drive on road and manually apply trailer brakes. At stopped position 1 volt or less goes to brakes. Not a failure, as per Ford. They have a bulletin out that explains in greater detail. I think it sucks, but doesn't suck enough to replace. Allegedly not a problem at a DOT stop, which I truly question.
Old 03-24-2007, 12:27 PM
It seems being in motion is the solution. After setting gain as per manual, using the foot brake at 20 mph, with the windows down, I can hear the trailer brakes engage. The build date on truck is 10/2005. Thanks for all input.
Old 03-24-2007, 12:45 PM
Glad you got it figured out Ron.
First tow and trailer brake observations tracyclifton 6.7L Power Stroke Diesel 7 07-09-2015 11:08 AM
No trailer brake when applying truck brakes. Technologiq Excursion - King of SUVs 7 06-28-2015 05:05 PM
Dexter electric Brake problems SS70ElCaminoOwner Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 30 07-11-2014 08:51 PM
Ford Integrated Brake Controller Mud Doc Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 9 06-24-2013 02:59 AM
1993 f-350 brake controller jaredlitch Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 10-01-2011 09:53 AM
Tags
2006, 250, brake, brakes, control, controler, controller, dash, diesel, f250, failure, ford, gain, integrated, settings, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
