The magic three things to do for your high mileage gas superduty!
I purchased a very high mileage superduty V10. While it drove very nicely and ran strong, I followed FTE's advice and did these three things:
As a p.s., wear safety glasses when changing the fuel filter. I bled the pressure from the fuel system, but the filter bracket was holding a ton of dirt that liked to drop in your face while you are lying underneath it (assuming you don't happen to have a lift in your driveway).
- Cleaned the MAF sensor
- Changed the fuel filter
- Swapped in Bilstein shocks
Electronic parts cleaner. CRC makes one that is available at auto parts stores, otherwise visit radio shack or another electronic parts store.
DO NOT touch the wire sensor with anything! Spray only.
The hardest part of the job is detaching and reattaching the sensor wire, which plugs in to the sensor inside of the big plastic air tube.
Next time I'll separate the air intake before and after the sensor, but leave the sensor wired up and clean it under the hood of the truck.
O.K., I'm adding a fourth thing. cost = $0.
My 350 was super-stiff. What you would expect out of a 1 ton, but uncomfortable anyway on potholed streets, longer trips, etc.
The tire shop put the pressures at Front 70 Rear 75. I dropped them to Front 57 Rear 54 and now I can ride through potholes without a kidney belt...
Of course I'll pump 'em up a little for heavy loads, but most of my hauling is utility hauling, using nowhere near the weight capacity of the truck.
Just a side note on changing your own plugs: I did mine (5.4L F250). And apparently botched it. Long story short, a plug shot out of the cylinder head taking the threads with it. I tried the rethread kits and it was too damaged. So $3700 later, (and a lot of aggravation) I have a new cylinder head.
Let a shop do it. Then they are liable if anything goes wrong.
Originally Posted by sgthawkusmc
I doubt you botched it. I've heard that happening way too many times. The threads were probably screwed up to begin with.
The plugs have to be maintained. Either every 2-3 years or 60K miles they need to be removed, cleaned, possibly replaced with the zinc-plated ones if you're still on the orginals, anti-siezed, and torqued down the right way.
