put a diesel in a bronco II? - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 03-23-2007, 03:33 AM
warriorprophet8 warriorprophet8 is offline
warriorprophet8 is starting off with a positive reputation.
i am just wandering if there is a good diesel engine out there that i could drop into my '88 Bronco II. i read on some other sites that ford made a diesel version until '87 but that it was not a reliable engine. any suggestions and opinions will be appreciated.
Old 03-23-2007, 09:17 PM
bomberboat's Avatar
bomberboat bomberboat is offline
bomberboat is starting off with a positive reputation.
try a nissan diesel there are two of them get the one that they use in there fork lift's it's a very good one i had one in a nissan extended cab p/u not a lot of hp or tourque it has removeable cylender sleeves also look on sone nissan 720 truck fourms there is one i know. cant remember ther name sorry.
Old 03-24-2007, 12:13 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
The Ford 2.2L diesels were kinda weak or had a bad rep, but the 2.3L turbodiesels weren't too bad, if I remember right. The old Nissan diesels are good, as well as Isuzu, Volkswagen and Toyota. You could get really oddball and find a Kubota, John Deere, or Caterpillar 4-cylinder diesel and swap it in. I think for power and economy, though, one of the best I have seen lately would be the Volkswagens (1.8/2.0 TDI Jettas) as far as smaller engines. Just remember, though, diesel engines are usually heavier, so you may have to level out your front end and whatnot. Wouldn't surprise me if you could "tune" an 'original' 2.3L Ford turbodiesel engine.... and your best bet on finding one would probably be in Canada.... good luck importing that!
Old 03-24-2007, 04:34 PM
todd koebel todd koebel is offline
todd koebel is starting off with a positive reputation.
I was kind of curious if you could modify an old tractor diesel to fit in a bronco II. I love the old International diesels (tractor ones). They have few electronics and too much torque for their own good. Plus you clould get your pick of size and power.
Old 03-24-2007, 05:31 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Ford of Austrailia offers a diesel for their Ranger. Try:
http://www.ford.com.au/servlet/Conte...idth&c=DFYPage
I'm not sure how you would be able to get ahold of and import one. That would be the catch.
Old 03-26-2007, 01:39 PM
Yep, Europe, Australia, Canada... pretty much ANYWHERE but the USA offers diesels in most of the cars that DON'T offer it as an option here. I'm sure the new Ford Ranger diesel engines are a lot better than the older ones. Todd, I hear ya there. I think the big issue would be bolting up a transmission that will handle that kind of torque. The other key factors to consider would be axles, driveshafts... pretty much the rest of the drivetrain. You wouldn't want to snap anything
Old 03-27-2007, 11:41 AM
bomberboat's Avatar
check it out go to www.BroncoII.org in the general discussion forum is a guy (brickhead) user name. from lancaster,pa that has a cummings diesel 4bta turbo charged no less in a B2 well it's a full size frame with the WB shortened 10 " and a BII body on it. still if it fits between the fenders it will work on any BII or ranger
Old 03-27-2007, 06:57 PM
OMG... that is exactly what I was looking at doing myself. Cummins 4BTAs are stout engines and have a lot of power and torque. I guess if you're not so much about the speed but the power to go through anything... the only thing I could see is the weight issue, but I guess if you have the right axles, gears, tires, etc., it'll work out well. One of the things you have to remember is the fact that you're probably looking at either flushing or replacing your current fuel tank and possibly all the fuel lines in between. I tell ya, this makes me want to put this in the list of things to do to mine.... check this out... Cummins 4BTA-powered Bronco II
Old 03-28-2007, 12:46 AM
bomberboat's Avatar
pretty cool
Old 03-28-2007, 08:13 AM
That video would be brickhead's BII starting for the first time, too. That's just wicked!
Old 03-29-2007, 08:46 PM
BII Plow Truck BII Plow Truck is offline
BII Plow Truck is starting off with a positive reputation.
Many people use the abundant VW diesel engine in their 4x4 Geos and Suzukis and get mid-30s mileage.
Old 03-30-2007, 06:05 PM
bomberboat's Avatar
my father inlaw had a VW rabbit diesel. great on milage but took three blocks to get up to 35 mph. no ***** at all.
Old 03-30-2007, 08:54 PM
The newer VW turbodiesels have plenty of *****. The older ones weren't so great, but it wouldn't surprise me if you could tune 'em and tweak 'em and get better power/torque numbers.
Old 03-31-2007, 12:33 AM
My 99 VW TDI diesel dyno'd 255 lb-ft torque at only 2000 rpm! That's an estimated 300 lb-ft at the crank! I surprise V8s on the road and at the pump.
53 best / 48 average / 42 worst
Old 03-31-2007, 11:56 AM
steve87_gt steve87_gt is offline
steve87_gt is starting off with a positive reputation.
Im glad I wasnt the only one thinking about doing this!! I have been looking into ANYTHING to replace my 2.9 v-6. By the way, if anybody needs any parts made, I can do some really nice work in the shop. Im a machinist, and I make my own stuff alot. Drop me a line if ya need anything.
Broncos II HELP!! southpaw776 Ranger & B-Series 6 04-19-2015 08:48 PM
BRONCO II ARE COOL RIGHT?! 86fordbronco_ii Bronco II 3 08-18-2014 08:12 PM
Why is a bronco II called a bronco II? mdr617 Bronco II 20 03-17-2011 12:01 PM
89 2.9 Bronco II to 4.0 Engine swap pianoman Engine Swaps 4 05-16-2008 09:18 AM
Will 33's fit on a 1987 bronco II with not lifts TylerG Bronco II 9 04-29-2004 01:35 AM
Tags
22, 4bta, bronco, cummings, cummins, diesel, engine, ford, ii, motor, plow, putting, swap, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
