Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 03-22-2007, 08:48 PM
Motorhead26's Avatar
Motorhead26 Motorhead26 is offline
Garage is empty, add now
Motorhead26 is starting off with a positive reputation.
Step by step procedures on body lifts
OK guys, we all know that when something is ordered in the mail we are at the mercy of the retailer whatever it might be. No matter how much we ask for help or call the customer service line nothing seems to answer any of the questions we have. This is a post for those who have done a body lift and know what process it takes. These are not always easy unless you have the time or experience. For some of us this is more great info for use to hand to other truck guys/gals that need a hand, as well as myself.
Items: Body mount bushings (probably some that are new since that would be the smart idea) Bolts, nuts, brackets, whatever inch blocks for the lift project. Remember STEP BY STEP info about how and what to do. This is for helpful information to me and others. This should really help me or anyone else who is in this do-it-yourself phase.
The first thing is I have new polyuerathane bushings to replace the old rubber ones. The old ones have been cut out with a sawzaw because they were to damn rusted in there to do anything with.
Sawzaw
http://i151.photobucket.com/albums/s...6/IMGP0820.jpg
Cut in two
http://i151.photobucket.com/albums/s...6/IMGP0824.jpg
Now that they are out I have no idea if I need to reuse the bolt that is tack welded to the nut, on the bottom, that the old bolt screwed into(retainer sleeve). If I do...how? Do I need a new retainer sleeve? Advice, it is confusing! Please post in detail and post pics if possible.
Motorhead26
__________________
Motorhead26
[Aspire to Inspire before you Expire]
  #2 (permalink)
Old 03-30-2007, 09:18 PM
Thanks for all the insite?? I found out from a couple of dependable ford truck users on here such as Franken Truck...KUDOS bro!! I probably could have reused these if I took them out the right way, but I will be replacing what I cut now. If I only knew what I know now.
This picture is the two new poly bushings to the rear of the cab and how to put them together step by step.
First is the pieces....
http://i151.photobucket.com/albums/s...6/IMGP0867.jpg
Bushings on the retainer sleeve....
http://i151.photobucket.com/albums/s...6/IMGP0870.jpg
New Poly bushings with 3" block on top....
http://i151.photobucket.com/albums/s...6/IMGP0872.jpg
The bolt slides through the middle and screws into the original sleeve to bolt to the frame....
http://i151.photobucket.com/albums/s...6/IMGP0875.jpg
From left (bottom)under frame, right (inside) cab....
http://i151.photobucket.com/albums/s...6/IMGP0876.jpg
I hope this helps anyone who gets any kit with BS directions. No pictures no detailed explaination and every intention of having someone else do it and pay them 500 or more to do it. A waste!! If you ask me it really isn't all that hard. The hard part was learning if you find that hard. Tomorrow I go and pick up my NEW core support and then I have to check out the yards for some front cab retainer sleeves and then put her back together again. I will post everything on my before and after thread.
Motorhead26
__________________
Motorhead26
Tags
body, econoline, excursion, lift, mounts, procedure, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
