Ignition system right year for my truck? - Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Old 03-22-2007, 05:55 PM
oneminizut's Avatar
oneminizut oneminizut is offline
oneminizut is gaining momentum as a positive member of FTE.
I was talking to Ford_Six about this but I think he's been pretty busy with work. What I have is an 83 f250 with the 351 5.8l
He came and looked at my truck and told me to get a durasparkII with the blue grommet and a distributor for a 78' year for the windsor motor. Now I found a package for sale with the distributor and the blue grommet durasparkII but it's from a 77' and not a 78' like he told me. Now normally I could be patient for his reply but some circumstances have just changed and I really need to get this truck on the road. Any help appreciated!
Old 03-22-2007, 09:09 PM
Placermike's Avatar
Placermike Placermike is offline
Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.
You can always try your Ford dealer to find out compatabilty, or the tech guys at Summit.
Old 03-22-2007, 09:21 PM
oneminizut's Avatar
This is getting to be a little more difficult / strike that, alot more difficult than the original problem I thought I had.
Old 03-23-2007, 12:21 AM
oneminizut's Avatar
Ok, Jared straightened me out with it. BTW, sorry for the double post but I'm not a moderator so I can only edit for an hour.
Old 03-23-2007, 09:58 PM
Placermike's Avatar
Quote:
Great that Jared got you the info! As far as the post editing, I am not sure about that hour thing! I have made some posts that I wanted to edit, and could do it right after the fact most of the time. I have had some that I could not. My guess is that it depends on whether or not someone saw the post and responded.
Old 03-24-2007, 07:51 AM
oneminizut's Avatar
Well, I still got the highest bid for the whole ignition system on ebay for the 77' so I'll see what happens. A bunch of guys on the regular f150 and larger 80-' to 86' have been helping me as far as trying to install it properly. I wish I could afford the timing light on top of it. Guess I'll do it the old fashioned way.
Old 03-24-2007, 12:08 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG MARTYSTOWRIG is offline
MARTYSTOWRIG is gaining momentum as a positive member of FTE.MARTYSTOWRIG is gaining momentum as a positive member of FTE.
where do you live? i have a timing light you can borrow
Old 03-24-2007, 12:45 PM
oneminizut's Avatar
Quote:
I live in Spanaway... and you could check out the lot to see if it's fit for racing yet. I may need to cut some scotchbroom back for a wider track because I usually only drive just my truck down the path and its a little tight in spots. Not that the scotchbroom bothers me. If I need to get somewhere I'll run it over.
Old 03-24-2007, 12:51 PM
well I can get it to federal way by tuesday if you need it. You would have to pick it up and get it back to me.
Old 03-24-2007, 01:21 PM
oneminizut's Avatar
You know, as embarrasing as it is. I don't even know how to use the darn thing. And I'm still waiting to make sure I win the bid on my parts from ebay.
Old 03-24-2007, 01:22 PM
ok Let me know
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
