F-250 4wd - Auto, or Stick Shift? - Ford Truck Enthusiasts Forums
Old 03-22-2007, 02:27 PM
Mitchissippi's Avatar
Mitchissippi Mitchissippi is offline
Mitchissippi is starting off with a positive reputation.
New on here, but it looks like one can gather up pretty good advice around the board.
I'm fixing up a '78 F-250 4wd manual shift to use around our place and occasionally pull a goose neck no more than a couple hundred miles and back. Most of the time the truck will run locally - very local 'til I get around to really tightenin things up.
My question is this: Do you prefer a manual shift or automatic in these trucks?
This one will not be a daily driver. I'll use it around the place in the evenings and on weekends to do chore work, pull out the neighbors, and haul stuff home from a sale or two a year. I'd like it to be dependable enough for the wife to drive it to town if she needed to.
I'm looking at another truck like it that has an automatic transmission. I can't decide which tranny I'd rather have.
what do y'all think?
Mitch
Old 03-22-2007, 02:47 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
I am a MANUAL man all the way, reasons why; if your battery is dead you can push start it, no tranny lines to get hooked and ripped off and kill your tranny, Granny gear!
anyone can drive an auto, clutch goes out you can always get it home under its own power, and I just think they are more durable over the long run.
Old 03-22-2007, 03:14 PM
Bouts21's Avatar
Bouts21 Bouts21 is offline
Bouts21 is starting off with a positive reputation.
I like the manual option, but it's up to you in the end.
Old 03-22-2007, 03:57 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Manual tranny is definately better for pulling those big goosenecks as you can start out in Granny Gear easily and no need to worry about burning up your automatic. Also, better for pulling out your neighbors. Automatic is great for cruising around, but your not wanting a cruiser. But, if your in a lot of stop and go traffic or something like that, than an automatic will be best.
Old 03-22-2007, 04:00 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Welcome to the site
Automatics are the preferred Transmissions for towing a travel trailer
I can see some people liking first gear for yanking a work trailer out of a hole but once on the road... Not ...
Ford doesn't even list a standard trans in their towing specs.
A C6 is all you need.
Maybe check the Towing forum for this info you need.
That's what that forum is actually for.
Old 03-22-2007, 09:10 PM
plowpusher plowpusher is offline
plowpusher is starting off with a positive reputation.
I have towed heavy loads with both,personally I liked my 4spd better got off the line better was easier to slow down. I feel the c6 robs to much power and if you know how to shift a 4spd it can be just as smooth.
Old 03-22-2007, 11:01 PM
brentleedragon's Avatar
brentleedragon brentleedragon is offline
brentleedragon is starting off with a positive reputation.
i like my c6 personally, it seems to tow things extremely well, I havnt had much problems at all with it, its all about preference, i prefer auto because im in stop and go and c6's are great for towing in my opinion, also for traveling well for me its 30 miles into the closest towns and I take hills and all that, and i like not having to shift
just preference
Old 03-23-2007, 12:20 AM
I'm mostly gonna be crawling around 45 acres in this truck. I have rolling pasture - that's slick when the dew is on, some bottom land that has a couple mud holes in the winter time, soft woods roads, and new road up a pretty steep hill - my 2wd prolly won't climb it in dry weather without a running start - and there's no room at the foot for a running start.
All I've ever owned has been 1/2 ton, short bed trucks. I bring a company truck home every night now, so I bought this old work horse to ease the load on the haftonners. For once in my life - I want one truck that I can have a loaded cross-over box, my fuel tank, my chain saw and all it's pairfenalia (sp?), my chains & binders, shovels, bush hook, garden hoe, tool box, jacks, oil buckets, blocks, beer cooler, cheater pipe, WD-40, half a roll of barbed wire, 22 rifle, 20 ga., coveralls, jumper cables, lug wrench, sledge hammer, wire strecher, crow bar, . . . well, you get the point.
So far, the heaviest load I pull is a 35 horse tractor and a brush hog, or disk. Short hauls over to one of the other places I help take care of. A load of lumber now and then. Bumper pull now, but would like to step up to a goose neck in the future. I can borrow a dually if the load gets too heavy for the 3/4 ton.
You'd think I worked a thousand acres by the way my truck looks. I get called on to lend a hand by a lot folks. They know I can get'er done. And I like being ready. Plus, I'd like to have my nice clean half ton waiting in the car port for Saturday night.
I love shifting gears. I've never done chore work out of a stick though. Ain't skeerd to try it. A man can get used to anything . . . . . but hangin'.
Thanks for bouncing it back fellas.
Mitch
Old 03-23-2007, 09:41 AM
FordTrucksKickGM FordTrucksKickGM is offline
FordTrucksKickGM is starting off with a positive reputation.
I perfer the auto with a good tranny cooler. But since your manual works fine Id leave it alone. I wouldnt switch it to auto unless it crapped out. Both trannies have advantages and disadvantages.
Old 03-23-2007, 12:58 PM
Then a standard trans will be better Mitch.
If you even need to rock it to get out of a bad spot yuou will have the right tranny.
Old 03-23-2007, 03:03 PM
Well, it looks like it's gonna be a manual shift. The deal on the truck with the automatic doesn't look like it's gonna happen. So, I'll continue tinkering with the truck I have.
I did just buy a good '73 2wd 1/2 ton body for parts. I gave less for the whole thing than the glass I need would cost me. Gotta go fetch it tomorrow.
Mitch
ESOF Woes - This one is complicated sevensecondsuv Excursion - King of SUVs 6 01-02-2017 03:23 PM
Shift on the fly Dom165 1999 to 2016 Super Duty 18 01-22-2016 09:50 AM
Manual Transmission Fluid (ZF6 six-speed) corksil 1999 - 2003 7.3L Power Stroke Diesel 6 12-01-2015 10:18 PM
1965 steering column rebuild fordsforever2015 1961 - 1966 F-100 & Larger F-Series Trucks 6 11-06-2015 06:09 PM
2000 F350 Transmission Shifts Fine with O/D disabled. JustinAK5 1999 to 2016 Super Duty 7 03-26-2015 06:55 PM
Tags
2004, automatic, f250, ford, shift, stick, stickshift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
