JetA
Old 03-21-2007, 09:40 PM
Reddirt's Avatar
Reddirt
Reddirt is offline
JetA
Is there a big difference between Diesel and JetA?
Old 03-22-2007, 07:23 AM
kennedyford's Avatar
kennedyford
kennedyford is offline
Welcome to the forum.
Jet A is a similar kerosene type of fuel, produced to an ASTM specification and normally only available in the U.S.A. It has the same flash point as Jet A-1 but a higher freeze point maximum (-40°C). It is supplied against the ASTM D1655 (Jet A) specification.
Yep, alot
Old 03-23-2007, 08:59 AM
Reddirt's Avatar
Reddirt
Reddirt is offline
Can I add anything to JetA to use in a diesel engine? We through out over 50 gallons every time we sump an aircraft.
Old 03-23-2007, 02:45 PM
kennedyford
I think you should be able to cut 50/50 with reg diesel. Add a lubricant. Kero has lil or no lube properties. Kinda like the new low sulfer fuel we are all being scammed at the pump on.
Old 03-26-2007, 09:32 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Cut it 50 - 50 with BD and no lube supplement needed
Beagle44
General Diesel Discussion
85
11-13-2013 02:58 PM
Haymanwolf
11-23-2007 04:19 PM
Chris60F100
07-26-2005 10:05 PM
olfordsnstone
05-30-2005 07:44 PM
Quick Reply: JetA
