JetA - Ford Truck Enthusiasts Forums
JetA
Old 03-21-2007, 10:40 PM
Reddirt Reddirt is offline
Reddirt is starting off with a positive reputation.
JetA
Is there a big difference between Diesel and JetA?
Old 03-22-2007, 08:23 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Welcome to the forum.
Jet A is a similar kerosene type of fuel, produced to an ASTM specification and normally only available in the U.S.A. It has the same flash point as Jet A-1 but a higher freeze point maximum (-40C). It is supplied against the ASTM D1655 (Jet A) specification.
Yep, alot
Old 03-23-2007, 09:59 AM
Can I add anything to JetA to use in a diesel engine? We through out over 50 gallons every time we sump an aircraft.
Old 03-23-2007, 03:45 PM
I think you should be able to cut 50/50 with reg diesel. Add a lubricant. Kero has lil or no lube properties. Kinda like the new low sulfer fuel we are all being scammed at the pump on.
Old 03-26-2007, 10:32 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Cut it 50 - 50 with BD and no lube supplement needed
Jet-A1 as cheap alternative Diesel fuel. Beagle44 General Diesel Discussion 85 11-13-2013 03:58 PM
Mix in a little jet fuel? Haymanwolf 6.0L Power Stroke Diesel 6 11-23-2007 05:19 PM
Using jet fuel? Chris60F100 6.0L Power Stroke Diesel 14 07-26-2005 11:05 PM
JP8 / JetA fuel in a 6.0??? olfordsnstone 6.0L Power Stroke Diesel 15 05-30-2005 08:44 PM
Tags
ford, jeta, jetaford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
