Need some Y-block gu-ru advice
Originally Posted by haten'chevs
Yep I'm here- I was at the tractor pull in Lincoln Ne last weekend so I'm just getting back around to this-
I like the look of your motor!!! I like the look of the 3 dueces more BUT I just KNOW I dont wanna **** around with them. I'm more of a start and go kinda guy!! How about 2 4bbls?? They bad to deal with?? How do I get ahold of John?? He got a website?? Great info- thanks for the heads up on the pistons!!! Pretty sure thats what I will end up doing on the bore. What factory 4 bbl manifolds fit?? From what I see on ebay they go cheaper then aluminum after markets, and painted would kinda go with the "look" I want I think. Is Ebay my best bet for parts??
Thanks
Rob
Thanks
Rob
Yes three deuces look great! Almost each time I see them the first ride in a 64 GTO with 3 2's comes to mind, and it was the fastest thing I'd ever been in. Roger's motor is another great example. Very cool. However in my quest to keep life as simple as possible, one well working carburetor is enough.
Forget about more than one small 4 bbl carb. You are building a truck engine for towing and you need bottom end, not top end. Even a good 2 bbl gives better bottom end because you don't lose your mixture velocity with full throttle at low rpm. You should find a steel crankshaft (I just happen to have a nice one) and a set of ECZ 312 rods. Get a set of HD 292 pistons and bore to the 292 size. If you can find a set of 113 heads or a good set of the HD 292 heads (they have the biggest intake valves and are posted to be able to stand extreme cylinder pressure) you will build a very agreeable and usable engine for your situation. Either the rams horns or the t-bird exhaust manifolds would be a good addition. By the way I also have a good supply of big valve heads. I dunno, these engines are like puppies, they keep following me home.
Forget the multi carb setup for a towing truck. A small 4bbl of under 500 cu ft. would be ok, but really, a good 2 bbl gives the best low end because you don't lose the mixture velocity under low rpm full throttle. Get a good steel 292 crank (these were used on the truck engines and you may already have one, it is stamped C1TE) Also use the shorter ECZ 312 rods with the HD 292 pistons which have a higher top to compensate for the short rods. Don't forget that, the wilder the cam, the less driveable it is at low rpm with high load conditions. Actually a standard truck cam would drive the best. If you don't already have big valve posted heads, you should get some. These heads are "113" or the 292 or 312 truck heads after 1959 (I think). You will have a truck that will pull your load and be agreeable at it. A pair of rams horns or the t- bird exhaust manifolds will make it breathe a little better and sound a lot better. I have a good number of the parts you need, if you can't find them anywhere else. Problem is, I know what they are worth and you may be able to find someone who doesn't. Lots of luck with the project. I've been working on flatheads for over 50 years and Y-blocks since they first showed up.
Engineman, I hear what you're saying about the 2bbl keeping the charge velocity up at low RPM on a truck engine. I'm still wondering, however, about the potential for the (correct) 4bbl to maintain highway speed better when pulling a grade at 3000+ RPM. I'd sure like to have another 5mph at the top of the hill. What do you think?
From the Y-block site:
"The 1957 cam for supercharged engines was part number B7A 6250 C."
I thought I was the probably the only person on the planet that knew that number. I had to buy one for my '57 supercharged 312. Long, long ago.
Back to the 272 in a truck-- cubic inches are your friend, especially in a truck engine. Bore it out as much as practical to get more cubes. One small, vacuum secondaries, four-barrel will be much better than a multiple carb setup.
for a carb, Holley has a 390 cfm vac 4bbl. Thats only 200cfm from the primaries, and it shouldnt run out of breath (at 292ci) until 4500+. Its actually not that bad a carb, got one on my 84 Ranger 2.8 (171ci). I dont think the secondaries ever open, but it does pretty good for the engine size. Well, they open when the misses isnt around
So Here Goes Probably does not belong here per say but since i'm in IRAQ I cannot Start a new thread so Has anyone of you guys ever heard of a ford 430 CID y-BLOCK at least thats what it looks like (y-block I mean) I am wondering if I am being given bad info or someone simply dislexified the CID numbers Here is a picture I hope Nevermind can't go advanced for the post..... Looks like a Y-block with the ram horns and spider like intake and 45 degree mounted rear distibutor, any Ideas I am hoping to place this in my 1963 ford N-700 as the 292 I have is absolutely guttless and is supposed to be a rebuilt engine (Maybe they did one of the things I was just reading about on the y-block .com page in that they may have improperly placed the new timing gears???) (does anyone know if a Y will run at all with the gears placed with the pointers faceing each other like you would a newer FE Style engine when you replace the timing set) Ok so that was an awfull lot of question for one post I would appreciate any ideas or suggestions you guys have as I'm an FE type of guyu and the Y block and FT's are something totally new to me
Please Reply to Kbart-@hotmail.com
I think Lincoln made a 430 ci motor. Don't know if it is a "Y" block or not as it has been so long since I crossed paths with that one, I can't remember.
An N700 is pretty heavy by itself and by the time you load it up, I can see why you'd want more power than a 292. We had a '55 F600 with a 292, 4 & 2 and it did pretty good but it only had a 1000 gallon water tank on it.
Take care of yourself in Iraq. Never mind the news media and politicians ...we the people support you.
#28
#29
430 Mel
You are talking about a 430 cu in. motor that came in Lincs, Mercs, and Edsels. There were 383, 430, and a larger displacement. It wont fit your bellhousing. Parts are dfficult to find, and aftermarket parts support fairly nonexistent. With stock pistons they were high compression motors. Most of the piston offerings now are flattop. Motors had big torque numbers. A couple guys that post here are working on them and one poster just gave one away. Probably not a motor for the inexperienced, underfunded, or impatient trucker.
