SD to MAF Conversion - Write up? - Ford Truck Enthusiasts Forums
View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would 485 94.91%
No thanks 4 0.78%
I duno, I might... 22 4.31%
Voters: 511. You may not vote on this poll
Old 03-21-2007, 09:28 AM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
I am making a poll to determine the interest level of a SD to MAF write up for our tech articles section. I just completed the re-wiring of a factory SD system to make it MAF using a mustang A9L computer (88-93).
It's pretty straight forward, and since ford doesn't sell their conversion kits anymore I thought it might be a good idea to write an article on how to do it. It also will allow you to use the dual o2 sensors that the mustang uses instead of the factory single o2 sensor that Ford's conversion kit uses (it splits the single signal into the two inputs rather than having two separate sensors).
So who's interested?
Old 03-21-2007, 09:35 AM
95Ford4x4 95Ford4x4 is offline
95Ford4x4 is starting off with a positive reputation.
is this a conversion for any motor or just v8's??? i have a 300-6, and would be interested in swapping it to a MAF system.
Old 03-21-2007, 09:49 AM
I did it on a 5.0/5.8 V-8 system...but the I-6 is going to be quite similar. I can try to add some info about the I-6 swap too, I have the diagrams.
Old 03-21-2007, 09:55 AM
currituckF150's Avatar
currituckF150 currituckF150 is offline
currituckF150 is starting off with a positive reputation.
With the drivability problems I'm having, plus to be able to make mods to the engine, I would love to convert to MAF.
Old 03-21-2007, 11:25 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
It might be nice to consolidate a lot of the information that is out floating around. If you need help with the article, let me know...I've completed the swap too, on my 87. It might be nice to get the perspectives of both years since 87 and 88 harnesses are different than the newer stuff that is more integrated into the under-hood chassis harness.
Old 03-21-2007, 11:37 AM
gustang818 gustang818 is offline
gustang818 is starting off with a positive reputation.
Great idea. Don't forget about the guys with E4ODs that would like to go MAF.
Old 03-21-2007, 12:13 PM
eco eco is offline
eco is starting off with a positive reputation.
Quote:
Since when?????
http://store.summitracing.com/egnsea...+115&y=16&x=19
I did it with the FORD RACING kit and one thing I would like to add is that THE INTAKE PLENUM DOES NOT HAVE TO COME OFF as the instructions says it does. I did the conversion in about 3 hours including breaks without removing the plenum. Lastly, I did it on a E-van and everything worked out great, but I was on my own with the plumbing from the throttle body to the mass air sensor housing. I had a y-pipe made out of mandrel bent stainless (dual 2 1/2 to 3) and a mandrel bent 3 inch 180 degree bend with a 6 inch center to center, also stainless, and with that and an AEM dryflow filter I had my intake system.
Old 03-21-2007, 01:32 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
Originally Posted by eco
.. I would like to add is that THE INTAKE PLENUM DOES NOT HAVE TO COME OFF as the instructions says... I did it on a E-van
I think it's necessary to point out that rear engine access is actually much easier on the vans compared to the pickups because of the removable engine cover inside the cab.
A tech article is a great idea IMO, if I were to do this again I would definitely source as many parts from Ebay/junkyard as possible... should be able to get the same results for a fraction of the price of the FMS kit. A complete DIY solution will take some electrical and plumbing(intake) fab skills though.
Old 03-21-2007, 02:01 PM
The trucks do not have great access to the rear #3 and #4 injector wires without removing the upper plenum.
It will definitely take some electrical know-how and skill, the plumbing part is pretty easy.
I should correct myself, according to what I read, Ford no longer produces the kit. The kit is still available through some dealers but supplies are limited (from what I understand, with Ford...who knows).
But even still, the kit is very expensive and doesn't use the 2nd o2 sensor. The 2nd o2 sensor is a good idea to have.
Old 03-21-2007, 03:54 PM
toddol1971 toddol1971 is offline
toddol1971 is starting off with a positive reputation.
I would like to know more about the benefits of it. Will this correct alot of the idle problems you read so much about? My 87 302 spikes to 2000 rpms sometimes when shifting the manual. I would like it to be a little smoother. About how much is the swap in kit form?
Old 03-21-2007, 04:02 PM
john112deere's Avatar
john112deere john112deere is offline
john112deere is gaining momentum as a positive member of FTE.
If I make a poor choice in the next few days (see thread "talk me out of it"), I might possibly be interested...
What would be the approximate cost for parts, and how technically challenging is the project?
Old 03-21-2007, 07:12 PM
eco eco is offline
Quote:
If you are talking about the notorious FORD surging idle that is caused by the SD computor not being able to run the engine due to a change in the volumetric efficiency of the motor, then yes, the conversion is a fix. I know this from experience as I have done this a few times.
Old 03-21-2007, 07:23 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Justin,
I'm not sure of the approach you intend to take with your SD --> MAF tech article, but if you want a writeup about a pure-junkyard solution I would be happy to do so.
And by end of this summer, I could also write a distributor-less version of the same.
Old 03-21-2007, 07:35 PM
eco eco is offline
Quote:
Yes, there are certain areas that are easier to work on with a van, but there are other areas that are more difficult...ie the front injectors on the passenger side. It's a trade off, it gets easier in some ways but more difficult in other ways but the job is just as time consuming either way and can be done either way without removing the plenum and if you ask me, not removing the plenum is the way to go...90 degree picks help big time.
Old 03-21-2007, 08:28 PM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
I always like to learn something new. do it
2nd O2 sensor on MAF converted f150 Ianator Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-31-2016 07:07 PM
89' F-150 302 build up Glaser67 1987 - 1996 F150 & Larger F-Series Trucks 3 08-09-2015 08:43 PM
All y'all MAF conversion gurus. A9 vs. truck ECM RC Dan 1987 - 1996 F150 & Larger F-Series Trucks 49 06-28-2014 05:45 PM
MAF versus SD.. gman97005 Fuel Injection, Carburetion & Fuel System 3 06-23-2013 08:01 PM
SD to MAF conversion firing order question menesesjesse 1987 - 1996 F150 & Larger F-Series Trucks 23 11-07-2012 10:57 PM
Tags
50, 58, aird, conversion, diagram, egr, ford, harness, injector, m9000, m9000t51, maf, pin, pinout, t51
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
