SD to MAF Conversion - Write up? - Page 5 - Ford Truck Enthusiasts Forums
View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would 485 94.91%
No thanks 4 0.78%
I duno, I might... 22 4.31%
Voters: 511. You may not vote on this poll
  #61
Old 04-10-2007, 11:59 AM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
It's taking me some time to write this...
unfortunately college comes first and i've been bombarded with assignments til the end of april.
I'll be lucky if I can get it done by the end of this month.
I will try to answer specific questions if users are doing it,need the info, and are waiting for my article.
  #62
Old 04-21-2007, 02:08 AM
BigRy's Avatar
BigRy BigRy is offline
BigRy is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Blurry94
For those looking to go with an aftermarket, plug-n-play kit;
PMAS/Flowmanagment Unlimited just released mass air conversion kits for E4OD and non-E40d trucks. The base E4OD kit utilizes an EEC-4 Mustang ECU, Bauman transmission controller and adapter harness (EEC and air meter not included). They have other options that include the air meter, air filter and EEC as well.
That kit is Expen$ive. I like the lower dollar way, but definetly am for the E4OD mass upgrade, I ahve a 91 4x4 with the E4OD.
  #63
Old 04-21-2007, 12:06 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Yes they are pricy, much like the previous E4OD/Mass Air conversion were as well; PSP, Kenne Bell, Ford Racing and Pro-M/PMAS. I installed a Ford kit on mine and it took about 2 hours and I was able to drive my truck after that.
I'm not trying to take away from the article Justin is working on, something like that is definately needed for the folks looking to do a mass air swap with used/salvaged parts. That type of swap will definately save some money.
  #64
Old 05-25-2007, 07:40 AM
currituckF150's Avatar
currituckF150 currituckF150 is offline
currituckF150 is starting off with a positive reputation.
MustangGT221, how's the MAF write up coming?
  #65
Old 05-25-2007, 08:23 AM
mgraveman mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
Maybe the controller for a 7.3 IDI with E40D may work too.
  #66
Old 05-30-2007, 08:48 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
That's a really interesting idea about the IDI transmission controller
  #67
Old 05-30-2007, 07:44 PM
Jrock909 Jrock909 is offline
Jrock909 is starting off with a positive reputation.
I am just getting ready to complete a mass air upgrade that I am currently using an E4OD tranny. I might be able to help out with the write-up if Justin decides to do a mass air write-up using the E4OD tranny....
  #68
Old 07-05-2007, 11:13 AM
devja71 devja71 is offline
devja71 is starting off with a positive reputation.
looks like this e40d thing is in demand, exnay on swapping the aod into my '92, put in the 89 low-mile 302 onto the '92's stock e4od, and still have the motorsport maf sitting on the shelf waiting to go in, so now i'm plagued with the e4od thing. i see the baumann getup advertised in the $400 range, but what all strings are attached? i've read a couple years ago of using the computer from an early powerstroked e40d and that sounds interesting.
  #69
Old 07-05-2007, 01:13 PM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
I just realized after reading this entire thread that I really do love my MAF on my '95 I-6. This '95 is the first FI vehicle I've ever owned. I love carburetors, but I have to admit that with 240,000 miles my MAF still hasn't given me a whole lot of grief.
Regarding the system "aging" better, I'll testify to it!
The E40D is still kicking hard too- I just yanked a friends 2500 Chevy out of a hole the other day on a trail with 2WD and chains tied up!
Is that article posted yet?
  #70
Old 07-05-2007, 02:15 PM
Not yet...
  #71
Old 09-06-2007, 09:40 PM
anyone know if it'd be difficult to run the motorsport mass-air computer side by side with the original truck computer to run the e40d? i thought i read somewhere couple years back that there is a way to convert to mass-air using the mustang or motorsport computer to run the engine and still using the factory truck computer to run the e4od with everything else disconnected. but i don't remember where i saw it. sure wish'd i was a computer whiz and figure out how to do this, make up a harness and plug it all in. well it'd also be nice to win a million bucks too.
  #72
Old 09-13-2007, 06:00 PM
Linemo Linemo is offline
Linemo is starting off with a positive reputation.
So guys after reading 5 pages on the MAF conversion I am still SOL because my truck is E4OD some body got any ideas on plug and play kits??
  #73
Old 09-13-2007, 06:42 PM
351slug 351slug is offline
351slug is gaining momentum as a positive member of FTE.
There is a company out ther that has a kit for E4OD for around 1800 bucks. Forgot who it is . Will post it when I find it. They say it is plug and play. I got from this forum.
  #74
Old 09-13-2007, 06:46 PM
Dirigo's Avatar
Dirigo Dirigo is offline
Dirigo is starting off with a positive reputation.
Quote:
Do you mean the Baumann TCS?
  #75
Old 11-23-2007, 02:27 AM
monkei's Avatar
monkei monkei is offline
monkei is starting off with a positive reputation.
The FI conversion wasn't too bad. I swapped injector wires 5w3 and 7w4 to get it to squirt in the 154 order that my valvetrain is set up for and it does alright. Now I have no more MAP or ACT, now its MAF and IAT, seems a bit more responsive and torquey but I haven't gotten to drive much:
I've been stuck on this damn conversion forever!! The signals the pcm is getting for the tranny arent quite right. I got the engine part working but it shifts like crap.
I took all my donor parts from a SFI 94 and put it on my SD 92. Looking at haynes engine wiring diagrams the trans harness is the same for both e40d's EXCEPT on the 94 trans connector 3 wires have different pin numbers and one wire(#30, lt blu/yel) on it isn't on the 92 trans harness. I might be able to switch the 3 wires to the old pinout and get the right signals through the right wires but I dont know what the extra wire could be for.
I think I'm going to bite the bullet and throw down another 250 for a superlift truspeed speedo calibrator (lifted, gears...) for a 94 rather than the one i have for a 92 but I don't think thats gonna solve the issue.
I don't know what differences there are between a 92 and 94 e40d but thats been my major hang-up on this conversion and nobody seems knowledgeable enough to help.
2nd O2 sensor on MAF converted f150 Ianator Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-31-2016 07:07 PM
89' F-150 302 build up Glaser67 1987 - 1996 F150 & Larger F-Series Trucks 3 08-09-2015 08:43 PM
All y'all MAF conversion gurus. A9 vs. truck ECM RC Dan 1987 - 1996 F150 & Larger F-Series Trucks 49 06-28-2014 05:45 PM
MAF versus SD.. gman97005 Fuel Injection, Carburetion & Fuel System 3 06-23-2013 08:01 PM
SD to MAF conversion firing order question menesesjesse 1987 - 1996 F150 & Larger F-Series Trucks 23 11-07-2012 10:57 PM
Tags
50, 58, aird, conversion, diagram, egr, ford, harness, injector, m9000, m9000t51, maf, pin, pinout, t51
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
