View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would
496
95.02%
No thanks
0.77%
I duno, I might...
22
4.21%
Voters: 522. You may not vote on this poll
SD to MAF Conversion - Write up?
#333
corect ecm pinout diagram
The problem with doing a detailed writeup is it would have to be different for each engine/trans/PCM combo and if you wanted accurate wire color codes it would have to be different for each year as well. Overall there are just too many possible combinations so that's probably why nobody has tackled it, and IMO I don't think it's necessary anyway, there is enough info contained in this forum for anybody to get it done with some specific help from others that have already done it if necessary. The good new is that no matter what EFI truck you have to start with most of the wiring you need for a MAF conversion is already there and it doesn't need to be touched for the most part. The simplest way to go about a conversion is to get a donor SEFI harness and disect it to remove the sequential injector and MAF wiring portions as complete as possible meaning all the way back to the EEC connector, then wrap these up in loom and tape to create a little overlay harness and add that to what's already in your truck. To do that you will need the wiring pinout for whatever PCM you're using, if it's a truck PCM you just have to add the sequential injector and MAF meter wires to the stock connector, but if it's a car PCM(Mustang/CougarTBird) some additional wires have to be moved along with installing the extra injector and MAF wires. The EEC connector comes apart to facilitate moving and adding pins so the hardest part of this is simply gonna be working in the cramped quarters under the hood, but if you minimize the work necessary as I have suggested I don't think this will be so bad. If anybody has any specific questions about this send me a PM, I'll do my best to help you out with your project.
95lightning using ECM part# E5TF-12A650-BYA. out of 95f150/Bronco, California emissions w/e4od, I have read alot of forums, and have got at least 4 different answers to the pinout of this Ecm, if you have the correct pinout diagram for this ECM, I really could use it right about now, lol, and also, the correct pinout for a 95lightning would also be of help, really want to get it right the first time, but am loosing hope with all the conflicting info, thankyou.
gwestmoland@gmail.com
#334
im doing 460 in 94 flareside withextras c6 3;73posi duals usual stuffi have to fuel and with no injector pulse was told wires need repinning etc but cant find what were and hows will run if spray fuel in it came outta truck i owned drove ran perfect as speed density now in mass air truck gotta get r done soon springs comin
Ianator
05-31-2016 07:07 PM
RC Dan
49
06-28-2014 05:45 PM
