SD to MAF Conversion - Write up? - Page 23 - Ford Truck Enthusiasts Forums
View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would 485 94.91%
No thanks 4 0.78%
I duno, I might... 22 4.31%
Voters: 511. You may not vote on this poll
  #331
Old 08-29-2014, 04:27 PM
rdbcole1956 rdbcole1956 is offline
rdbcole1956 is starting off with a positive reputation.
how about the use of 96 or newer ecm and wiring so you can put a tuner to it and really get the most bang for your buck? thank rick
  #332
Old 08-29-2014, 07:44 PM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
One member did a EEC-V OBD-II a number of years ago. 08-09 maybe? VERY involved. You need everything, I mean EVERYTHING. Seems he had crank sensor/mounting issues.
  #333
Old 10-19-2014, 01:22 AM
lightning 95 lightning 95 is offline
lightning 95 is starting off with a positive reputation.
corect ecm pinout diagram
Quote:
Originally Posted by Conanski View Post
The problem with doing a detailed writeup is it would have to be different for each engine/trans/PCM combo and if you wanted accurate wire color codes it would have to be different for each year as well. Overall there are just too many possible combinations so that's probably why nobody has tackled it, and IMO I don't think it's necessary anyway, there is enough info contained in this forum for anybody to get it done with some specific help from others that have already done it if necessary. The good new is that no matter what EFI truck you have to start with most of the wiring you need for a MAF conversion is already there and it doesn't need to be touched for the most part. The simplest way to go about a conversion is to get a donor SEFI harness and disect it to remove the sequential injector and MAF wiring portions as complete as possible meaning all the way back to the EEC connector, then wrap these up in loom and tape to create a little overlay harness and add that to what's already in your truck. To do that you will need the wiring pinout for whatever PCM you're using, if it's a truck PCM you just have to add the sequential injector and MAF meter wires to the stock connector, but if it's a car PCM(Mustang/CougarTBird) some additional wires have to be moved along with installing the extra injector and MAF wires. The EEC connector comes apart to facilitate moving and adding pins so the hardest part of this is simply gonna be working in the cramped quarters under the hood, but if you minimize the work necessary as I have suggested I don't think this will be so bad. If anybody has any specific questions about this send me a PM, I'll do my best to help you out with your project.
Hi, trying to convert to maf,
95lightning using ECM part# E5TF-12A650-BYA. out of 95f150/Bronco, California emissions w/e4od, I have read alot of forums, and have got at least 4 different answers to the pinout of this Ecm, if you have the correct pinout diagram for this ECM, I really could use it right about now, lol, and also, the correct pinout for a 95lightning would also be of help, really want to get it right the first time, but am loosing hope with all the conflicting info, thankyou.
gwestmoland@gmail.com
  #334
Old 01-27-2015, 01:18 PM
racinjason1969 racinjason1969 is offline
racinjason1969 is starting off with a positive reputation.
im doing 460 in 94 flareside withextras c6 3;73posi duals usual stuffi have to fuel and with no injector pulse was told wires need repinning etc but cant find what were and hows will run if spray fuel in it came outta truck i owned drove ran perfect as speed density now in mass air truck gotta get r done soon springs comin
  #335
Old 01-27-2015, 10:09 PM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
Do a search here or on google. You'll end up with a few days reading that should cover almost all your questions, an you'll find pin out diagrams.
Tech/mod info links strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 74 01-12-2017 12:46 PM
2nd O2 sensor on MAF converted f150 Ianator Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-31-2016 08:07 PM
89' F-150 302 build up Glaser67 1987 - 1996 F150 & Larger F-Series Trucks 3 08-09-2015 09:43 PM
All y'all MAF conversion gurus. A9 vs. truck ECM RC Dan 1987 - 1996 F150 & Larger F-Series Trucks 49 06-28-2014 06:45 PM
MAF versus SD.. gman97005 Fuel Injection, Carburetion & Fuel System 3 06-23-2013 09:01 PM
Tags
50, 58, aird, conversion, diagram, egr, ford, harness, injector, m9000, m9000t51, maf, pin, pinout, t51
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
