SD to MAF Conversion - Write up? - Page 2 - Ford Truck Enthusiasts Forums
View Poll Results: Would you like a tech article on how to re-wire your factory harness to MAF?
Yes, I would 485 94.91%
No thanks 4 0.78%
I duno, I might... 22 4.31%
Voters: 511. You may not vote on this poll
Old 03-21-2007, 09:03 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Quote:
Originally Posted by toddol1971
I would like to know more about the benefits of it. Will this correct alot of the idle problems you read so much about? My 87 302 spikes to 2000 rpms sometimes when shifting the manual. I would like it to be a little smoother. About how much is the swap in kit form?
There are many advantages.
The first and foremost is driveability - the idle is better and there is more snap off the line, because the mass air system measures the actual airflow instead of looking up a value in the table based on a drop in manifold vacuum as with speed density.
The second reason is hot rodding - the speed density is tolerant of small changes.. a little more cam, a little more exhaust, but too much of either and the speed density system becomes confused. Mass air systems on the other hand just measures what goes in, and blows it up and monitors the fumes coming out - so you can get away with a lot more cam, head port size, an exhaust than with speed density. Obviously to a point before the factory programming can't help you any longer.
Another advantage is if you use the mustang 89-93 mass air computer, that is probably the most reverse engineered EEC of all of them, so with a program like EEC EDITOR or TWEECER you can easily adjust the parameters in the EEC itself to handle your configuration - be it radical cam, 600+ cube mountain motor, turbocharged whatever, and so on. A lot of the other EEC's are also fairly well dissected, but because of the vastness of the Mustang Crowd you can easily find someone knowledgeable enough to answer the inevitable 100 questions you will have while working out your own tune for your combination.
The mustang bits are the least plug-and-play OEM bits you can shove into your truck, as there's a lot of wiring you'll need to do, but it's a tradeoff for having access to so many people with the info you'll need.
But I'd recommend that only if you're going wild. For a bit more cam, headers, better heads and so on, the mass-air truck stuff is fine and much easier to integrate into your pickup depending on the years of things.
But then the wild stuff can be fun. I and a friend are about 1/2 done grafting a 2002-ish explorer distributorless EFI system onto a 460 stroked out to 511 or 521 or something lke that. We got it started over the weekend, but it promptly died. But we're getting there.
Old 03-21-2007, 09:28 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
I'll do the write up on it.
The kit goes for about $700 I think. But doing it manually will add the 2nd o2 sensor which is the right way to do it.
I'll explain how I did everything, why I did everything, and include as much necessary information as I can. There will be many other ways to accomplish the same thing but I'll show how I did it.
You need some basic parts like MAF sensor, ducting, computer, pigtails, another o2 sensor, weld in new bungs and put a plug in the old hole, add wires to the harness, and re-arrange pins on the computer connector.
Thats basically it in a nutshell.
I have good pictures, I have the diagrams...I should be able to write it and submit it within a week or two. Next week is going to be busy but maybe the following week I can do it.
Old 03-21-2007, 09:50 PM
mgraveman mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
I am anxiously awaiting this.
I'm interested in doing this to a 460.....
Old 03-21-2007, 11:16 PM
Scndsin's Avatar
Scndsin Scndsin is offline
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Quote:
Originally Posted by gustang818
Great idea. Don't forget about the guys with E4ODs that would like to go MAF.
Ditto on this. There have been numerous folk with the E4s that drop by looking here for this. The only drawback has been the right PCM.
Old 03-21-2007, 11:25 PM
devja71 devja71 is offline
devja71 is starting off with a positive reputation.
you betcha. i have the motorsport maf kit on a shelf waiting to go into a 92 bronco. it's got the e40d though. think i'll swap in an aod i've got first. my biggest thing is throttle-response. my 89 does nothing but rev all the time w/the aod, dad's 89 f-150 has the 302 5spd mazda (i think) and all it does is rev between shifts and is awful hangtime. my 92 bronco 302 is much better, it idles down quicker and lower, ford must've re-programmed something. gonna swap the whole powertrain from the 89 bronco into the 92 and in w/the maf kit, and hope it idles down quick. i'd love to duplicate the early 70's 2bbl windsors that are very quick revving up AND down and a light throttle return spring.
Old 03-22-2007, 06:42 AM
KDOGDAMAN KDOGDAMAN is offline
KDOGDAMAN is starting off with a positive reputation.
I am a little confused as usual. I have seen several references to the years Ford used MAF's on 302 engines. I have a 1994 F-150, how do I verify what I have.
Old 03-22-2007, 08:22 AM
In 94 it was only on california emissions trucks, in 95 it was on some automatics (and cali). It's hard to pin down exactly what has what...but it's easy to tell.
If you don't have a sensor mounted in the air ducting to the throttle body, you don't have MAF.
I will not be doing an article on the E4OD swap. I will be doing it on a basic non-computer controlled V-8 swap with the exception of the I-6 and maybe some tips on a 460.
Old 03-22-2007, 10:37 AM
frederic's Avatar
Fair enough Justin, was just offering to pitch in. If you change your mind later let me know via email or Pm.
Old 03-22-2007, 10:57 AM
Tell ya what frederic...
I'll send you my article before I submit it and you can tell me what you think. I'm not sure what you'd be looking to contribute but any information that will lead to a better overall article (or multiple articles) is always good.
Old 03-22-2007, 11:40 AM
frederic's Avatar
Sure, would be happy to help.
I offered partly to help, and partly because I wasn't sure waht your approach was going to be - junkyard or aftermarket solution, or adding wires with crimpers, or what have you. As you know there are several ways to do this conversion so I was offering the "junkyard solution" in case that wasn't waht you were writing up
Regardless of that, I'd be happy to review your article and help out in any way on that as well.
Old 03-22-2007, 12:06 PM
eco eco is offline
eco is starting off with a positive reputation.
Quote:
Who is Justin???
Old 03-22-2007, 12:36 PM
frederic's Avatar
Our handy-dandy, supery-dupery moderator!
  #28
Old 03-22-2007, 01:13 PM
Jrock909 Jrock909 is offline
Jrock909 is starting off with a positive reputation.
I would love to see a SD to MAF conversion writeup, it would definitely be beneficial to me and alot of other people on here...
  #29
Old 03-22-2007, 04:02 PM
Neilster999 Neilster999 is offline
Neilster999 is starting off with a positive reputation.
Excuse my ignorance but what is a SD system and what does the SD stand for.....thanks......Neil
  #30
Old 03-22-2007, 04:09 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
SD stands for speed density, which refers to how the engine computer determines proper fueling for the engine. It uses the engine speed (rpm) and the density (manifold absolute pressure) as the main elements for calculation, then the figures from that table are adjusted based on input from the rest of the sensors.
2nd O2 sensor on MAF converted f150 Ianator Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-31-2016 07:07 PM
89' F-150 302 build up Glaser67 1987 - 1996 F150 & Larger F-Series Trucks 3 08-09-2015 08:43 PM
All y'all MAF conversion gurus. A9 vs. truck ECM RC Dan 1987 - 1996 F150 & Larger F-Series Trucks 49 06-28-2014 05:45 PM
MAF versus SD.. gman97005 Fuel Injection, Carburetion & Fuel System 3 06-23-2013 08:01 PM
SD to MAF conversion firing order question menesesjesse 1987 - 1996 F150 & Larger F-Series Trucks 23 11-07-2012 10:57 PM
Tags
50, 58, aird, conversion, diagram, egr, ford, harness, injector, m9000, m9000t51, maf, pin, pinout, t51
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
