oil pump gear on 226
Old 03-20-2007, 08:23 PM
frankcowan's Avatar
frankcowan
frankcowan is offline
Question oil pump gear on 226
I am rebuilding a 226 and need the oil pump gear or assembly, if i cant capture the gear by itself. Does anybody know where I could find one? Also I have noticed there are a lot of gears for the v8s.. does anyone know if any of those would work on the 226? thanks frank
Old 03-20-2007, 09:29 PM
ksmith203's Avatar
ksmith203
ksmith203 is offline
Kanter or eggie will have that gear. They have a rebuild kit for oil pumps. I got mine from Kanter. 800.526.1096
Old 03-20-2007, 10:22 PM
frankcowan's Avatar
frankcowan
Thanks Kevin - I will call them tomorrow.
Old 03-21-2007, 08:56 PM
frankcowan's Avatar
frankcowan
Kevin I called Kanter and talked with a 'Fred' that saids that they don't carry that gear. He said it wasn't in their catelog so he couldn't find it.
Is there a Kanter number or description or invoice number or even a sales person that helped you that might help them find it. thanks frank
Old 03-21-2007, 10:37 PM
ksmith203's Avatar
ksmith203
Frank try eggie then 866.996.egge kit # P-301 for a 1951 226 engine
or go online at www.egge.com
Old 03-22-2007, 07:20 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
226 I-6
OHA-6600-A .. Oil Pump 226 (& 254 1950/53)
OHA-6652-A .. Gear, Oil Pump & Distributor Driven ~ 226 (& 254 1950/53) 10 Teeth 1.164"/1.168" Gear O.D.
41A-6623-A .. Oil Pump Screen 226 (& 215; 223; 239; 256; 272; 279; 317; 337)
7HA-6650-A .. Rotor & Shaft-Oil Pump
The pump, gear and rotor/shaft will not exchange with the V8's.
Off chance: Green Sales in Cincinnati Ohio (800-543-4959) or
Sacramento Vintage Ford Parts (916 area code~dunno the number)
Try Hemmings Motor News too.
Old 03-22-2007, 08:57 PM
frankcowan's Avatar
frankcowan
Kevin and NumberDummy thanks for the parts house contacts. I will add them to my list.
I wouldn't have thought that part would be so hard to find. I found the OHA-6652 gear at Bob Selzam, 732-928-9421 in NJ thanks to V8ER
thanks again Frank
Partke
12-28-2016 06:53 PM
Spartacus1
01-31-2016 10:18 PM
Spartacus1
12-25-2015 07:26 AM
3twinridges
10-12-2015 08:34 PM
3twinridges
WTB - Parts & other
01-28-2015 08:18 AM
Quick Reply: oil pump gear on 226
