Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-20-2007, 06:40 PM
grnburg grnburg is offline
Garage is empty, add now
grnburg is starting off with a positive reputation.
Question fuel mods for a 6.9IDI
I will be FINALLY building a bioD still in the next week. Can anyone tell me what seals, rings, lines... in my 1986 F350 6.9IDI fuel system will need to be upgraded? I greatly appreciate the wealth of info in here.
  #2 (permalink)
Old 03-21-2007, 08:57 PM
Jacksfirstdiesel Jacksfirstdiesel is offline
Jacksfirstdiesel is starting off with a positive reputation.
I have an '86 6.9 turbo also which likes Bio. You don't have to change anything just get ready to. Make sure you have a spare fuel filter in the truck. Probably the first thing to change are the return line O-rings. It is recommended to go to Viton. Mcmaster carr has them they are part number 9464k24 and cost $6.31 per 50. You can do the return lines at the same time if they seem brittle. I haven't done mine yet.I can't remember if they are 3/16 or 1/4" you can find viton tubing also @ mcmaster carr.If you are handy it is real easy. first open all the injector lines and gently pull up on the return line caps one at a time give a little twist and wiggle no need to separtae the return lines unless you're changing them then carefully compress the o rings to one side with one hand and pull them off bottom one first. some toothpicks can help here. don't scratch the o-ring grooves with a screwdriver. grease up a new set -16- put them on top one first clean and lightly grease the caps put em back tighten the injector comp fittings. and run it. You can blleed the lines one at a time or put the pedal down and blow the air thru
Tags
69, bio, idi, mod, mods, viton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
