accelerator pedal position?
Old 03-20-2007, 06:19 PM
ponch37300's Avatar
ponch37300
ponch37300 is offline
Can you monitor the accelerator pedal position % and voltage with autoenginuity with the 6.0? On the 7.3 you can only monitor the %, but i thought i read somewhere that the 6.0 you can monitor accelerator pedal position voltage? thanks for any help
Old 03-20-2007, 07:00 PM
WishIhada7.3's Avatar
WishIhada7.3
WishIhada7.3 is offline
you can im sure...its just a potenteometer (sp?) probs works on a 0-5v signal...not sure which wires but with a voltmeter the output should be able to be read.
Old 03-20-2007, 07:13 PM
ponch37300's Avatar
ponch37300
You can with a volt meter but i am looking to see if you can do it with autoenginuity or other scan tool. I know on the 7.3 you can not read voltage with scan tools cause it doesn't have that sensor. You can read accelerator position % with scan tools on the 7.3. I thought i had read that on the 6.0 ford did put the voltage sensor on and you can read accelerator pedal position with scan tools.
learning diesel
1999 to 2016 Super Duty
06-20-2012 03:52 PM
04scurs
02-23-2012 02:43 PM
Piolet
08-24-2011 04:36 PM
ehgeeray
02-09-2010 05:22 PM
Dejablue2001s10
06-14-2005 12:07 PM
Quick Reply: accelerator pedal position?
