Replacing a Fuel Filter in 1998 Ford F150 - Ford Truck Enthusiasts Forums
Old 10-12-2002, 08:06 PM
z 97ford1 z 97ford1 is offline
z 97ford1 is starting off with a positive reputation.
Old 11-19-2002, 10:28 PM
jlb97 jlb97 is offline
jlb97 is starting off with a positive reputation.
I have a 4.6 liter triton engine and need to replace the fuel filter and do not want to pay a mechanic to do it. Does anyone have some instructions or have an idea where I can get my hands on some?
Thanks a ton!
Jay
Old 11-20-2002, 12:17 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
[updated:LAST EDITED ON 20-Nov-02 AT 00:17 AM (EST)]Haynes manual. You will need a $9 tol.
Brian A
Old 11-20-2002, 04:30 PM
geoaigel geoaigel is offline
geoaigel is starting off with a positive reputation.
The filter is in the passengers frame rail. Before disconnecting the fuel line you want to take the pressure out of the fuel system. This is done by disconnecting the inertia switch from the electrical system. (That will shut down the fuel pump). The inertia switch is underneath the pass. side kick panel. Once the fuel pump is disabled, crank the car. It will start and then shut down as soon as fuel pressure is gone.
Use a disconnect tool that you can buy at the parts store to open the snap in clips on both sides of the filter. Replace. Connect inertia switch and you are done.
Instead of buying the plastic universal tool you might be able to pick up a better (metal) tool, e.g. at www.thetoolwarehouse.net
George
Old 11-23-2002, 10:32 PM
dgabler dgabler is offline
dgabler is starting off with a positive reputation.
Instead of going through all that to de-pressurize the fuel system wait an hour or two (or longer) after shutting down the car. Worked fine for me on my explorer and '99-150. And yes I bought the cheap universal tool from kragen. Works fine once you realize how far you need to push it in.
Old 11-24-2002, 04:55 AM
fin2lean fin2lean is offline
fin2lean is starting off with a positive reputation.
On my '98 150 I just pulled the fuse for the electric fuel pump while the engine was running, and after a few seconds it quit running. This way all of the pressure is off of the line. I think the hardest part was getting the old filter slid out of the spring clip holder that secures the filter to the frame.
Paul
Toyota Tundra is compared to what Ford? mgazak General NON-Automotive Conversation 21 11-18-2002 12:51 PM
The Font that Ford Uses ? Vampiro General NON-Automotive Conversation 4 10-13-2002 09:08 PM
Does Ford own Cummins? Distinctive Dave 1999 - 2003 7.3L Power Stroke Diesel 6 09-10-2002 10:53 PM
Ford pulling out Chevy!!! mavman 1997 - 2003 F150 3 03-05-2002 12:59 PM
Ford VIN carllouis 1997-2006 Expedition & Navigator 1 06-15-2000 02:38 PM
Tags
150, 1998, 46, 4x4, changing, f150, filter, ford, fuel, fuse, locate, locating, replace, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
