Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #76 (permalink)
Old 04-09-2007, 11:17 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Good point, but couldn't find any studs. Didn't want to use Ford's again, no matter what they say.
I'll get those dirty *******s in, so help me
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #77 (permalink)
Old 04-10-2007, 01:33 AM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE. 1 is gaining momentum as a positive member of FTE.
How about some nice ARP bolts/studs? Never have to worry about problems with those.
  #78 (permalink)
Old 04-10-2007, 10:48 AM
Krewat's Avatar
I got plated grade 8 bolts that will work perfectly, and I'm using anti-sieze on them.
Problem is clearance. On certain bolts, I had to keep the header loose and then start them into the threads just to get the bolts in.
I'm using MUCH longer ones than what came with the headers. The supplied bolts got less than 1/2" into the threads. Way too little for aluminum ...
I'll be jacking up the driver's side of the engine today to get to the bottom bolts, I'm certain
__________________
  #79 (permalink)
Old 04-10-2007, 10:50 PM
Krewat's Avatar
Some pics, hopefully they wind up in the right thread this time
__________________
  #80 (permalink)
Old 04-10-2007, 10:53 PM
Krewat's Avatar
The engine is jacked up on the passenger's side, so they won't look like this with the engine sitting properly...
Whew! Some of them bolts were a pain in the butt. I am going to re-visit one on the passenger side, I couldn't get the long ones into that center bottom hole... too long. Had to use one of the shorty ones from the kit - and there's no way I'm leaving it with only 6 or so threads grabbing. I have to go find an inbetween one now...
Driver's side, still have to get two bolts in, # 7 and #8 bottom holes are another pain. Probably going to need shorter bolts there too...
It's fun using both index fingers to reach around the tube and try to thread in a bolt - when the flats of the bolt head are flush with the tubing - even when you try to lever the thing outward to get the room to get it in...
My shoulders are PUMPED.
__________________
  #81 (permalink)
Old 04-11-2007, 08:48 AM
dkf's Avatar
dkf dkf is online now
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Those E-Bay headers look pretty good. Look a lot like JBA headers.
You could just cut down a long bolt with a cut-off wheel on a dremel tool and file the threads so they start. Sometimes you just can't find the right length bolt.
  #82 (permalink)
Old 04-11-2007, 09:21 AM
Super08's Avatar
Super08 Super08 is offline
Super08 is gaining momentum as a positive member of FTE. Super08 is gaining momentum as a positive member of FTE.
Art do those puppies look real good. I agree on the Dremel tool idea. I've had mine since '82 and always find a use for it. I had to cut some bolts with mine two days ago putting a fifth wheel hitch in my new truck. What a job that turned out to be....another story for another day.
__________________
2009 F350 CC SB Lariat PSD Auto 3.55LS
MODS: Truxedo LoPro, LineX, Bed Mat, Hijacker hitch
  #83 (permalink)
Old 04-11-2007, 12:49 PM
sewerat's Avatar
sewerat sewerat is offline
sewerat is gaining momentum as a positive member of FTE.
so are you going to have to modify the exshust pipe to make it fit up to the new headers or is this a plug and play...so to speak. that is one reason i did not go with them when i did my manifolds in december is that i could not afford the time or cost of redoing the main pipe to fit onto the new collector so i opted not to for the time being.
__________________
2000 Excursion 4x4 XLT V10
K&N Filter, Flowmaster 40, Superchips Tuner, Bilsteins, Lift in near future
239.6 rwhp, 330.2 rwtq
2002 FLTRI Sewerats Site
In memory of my boy Duke. The K9 in the K9 Unit
http://home.cogeco.ca/%7Ecsulyma/Dukes1.jpg
  #84 (permalink)
Old 04-11-2007, 03:20 PM
Krewat's Avatar
So far, it looks to be a bolt-in. As long as you consider notching the frame "bolt-in".
Otherwise, yeah, it really REALLY looks like it'll just mate up to the stock y-pipe.
On another note, found better (longer) bolts for that one center bottom (#3) bolt on the passenger side. Still not as long as the rest, but definitely long enough for aluminum and the torque required.
Passenger side is IN. Notching the frame a little more (really increasing a radius), but other than that, passenger side is done.
WHEW.
Now on to the driver's side - after using the grinder that almost took my finger off two years ago
__________________
  #85 (permalink)
Old 04-12-2007, 10:27 PM
Krewat's Avatar
Didn't get out in the pouring rain today to do anything. Where I have the truck, it floods with about 3-4 inches of water when we get an inch or more of rain...
I'm just glad the jackstands on lumber are staying where they are... the mud back there is horrendous.
Anyway, will go out tomorrow and continue trying on the driver's side.
Still fighting three bottom center bolts... I can hardly get two index fingers around the tube to try to turn the bolt... and a wrench? Impossible when the bolt head is too close to the tubing. I might have to remove the steering shaft to get in there.
I did have to disconnect the steering shaft at the box to get the driver's side in. Make a note
__________________
  #86 (permalink)
Old 04-12-2007, 10:58 PM
mont974x4 mont974x4 is offline
mont974x4 is starting off with a positive reputation.
Those headers do look darn good.
*sigh* another thing to add to the wish list.
  #87 (permalink)
Old 04-13-2007, 12:09 AM
FORDTUF1 FORDTUF1 is offline
FORDTUF1 is starting off with a positive reputation.
KREWAT, Dude your making me feel like a Super Stud.
I put my JBA's on my 99 and it took me 10 hours, and I felt like crap it took so long. The only thing I had to do was cut down a 13mm combo wrench. Man I hated that, I now own a set of stubby wrenches.
I got my 02 and it took me 4 hours to swap the stock manifolds back to the 99.
By now I was getting the hang of it, it took 8 hours to get them on the 02. Wouldn't you know the gaskets then leaked after three years. But now I'm an expert 2 hours off and 4 hours back on, 6 hours total.
Guess what now, they are about 7 years old and they have a leak where the 5 tubes are welded at the collector. Here I go again, I think it's just a test to see if I can break the 5 hour mark.
  #88 (permalink)
Old 04-13-2007, 09:46 AM
Krewat's Avatar
FORDTUF1, believe me, I don't fell very good about myself taking THIS LONG.
But, broken studs, below the surface of the head, finding the correct length bolts, a few "gotchas" with these headers that might not happen with "brand name" ones, etc. etc.
It's taking a long time in elapsed time, but total labor, maybe 16-20 hours so far.
Trying to finesse things when I should have just gotten the cutting torch certainly cut into the time needed too...
Trying to work around things instead of just removing them, another bit of time.
Going to the auto parts and hardware stores around here at least TEN TIMES for various things, bolts, tap, you name it.
I also spent time painting the chassis on the passenger side, just to make it look nice for the final pictures.
Taking my time doing the job always rewards me in the end. So...
__________________
  #89 (permalink)
Old 04-13-2007, 11:07 PM
Super08's Avatar
Art are you able to post sound clips? If so, I for one would love to hear how it sounds once you are done.
__________________
  #90 (permalink)
Old 04-14-2007, 10:31 AM
Krewat's Avatar
Oh, I'm able, and will definitely do it.
I had to remove the driver's side manifold, something doesn't line up, hence the problems getting the last two bolts in. I'll delve into it an hour or so today, and see what I come up with. It might be the one bolt at the rear top, the hole is slotted, and I'm using a flat washer on it, which might be in the way ...
Anyway...
We have a nor'easter coming, supposedly one to rival any floods we've had in 30 years.
Yay... truck is in what will become the muddiest part of the yard... Maybe (probably) I'll build a lean-to today and see if I can dent/scratch the truck (some more).
__________________
Tags
2002 , 68l , bolt , broken , drill , excursion , exhaust , f250 , ford , manifold , problems , remove , stud , studs , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
