Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 04-03-2007, 01:35 PM
Carpainter29 Carpainter29 is online now
Carpainter29 is starting off with a positive reputation.
Talking
I guess the waiting game begins!!!!!!!!!!!!!!!
__________________
2007 F150 SCrew Lariat Chrome (everyday)
2004 Tahoe Z71 (wife's rig)
1978 Malibu 355ci, 475hp (my tire melter)
  #47 (permalink)
Old 04-03-2007, 03:19 PM
joe_jeep joe_jeep is offline
joe_jeep is starting off with a positive reputation.
what do you think it would cost roughly to have this done at quality exhaust shop??
  #48 (permalink)
Old 04-04-2007, 04:55 PM
Jones02SportTrac Jones02SportTrac is offline
Jones02SportTrac is starting off with a positive reputation.
Art -
Your experience caused me to look at my exhaust studs/bolts and I think I've found one that has backed away from the manifold. With a flashlight, I think I can see a gap between the nut and the manifold. I want to put a wrench on it and tighten it but I'm afraid of breaking the stud in half. What's your take? Do you think I should just attempt to loosen and re-tighten the nut or plan to take care of it when I want to replace the manifolds alltogether?
On a side note, one of the reasons I checked them out was because I hear a fluttery exhaust sound coming from the approximate location of the loose nut. Could the fluttery, hissy sound (which only happens momentarilly when the trailer is attached) be due to gas blowing around the stud?
__________________
02 SportTrack 4wd (120K)
00 Excursion Limited 4wd v10 (180K)
99 Expedition XLT 4wd 5.4Lv8 (120K sold 1/10)
25' Weekend Warrior Toy Hauler
  #49 (permalink)
Old 04-04-2007, 05:10 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation. Krewat has a spectacular reputation.
Sounds like it's leaking... the gaskets I took out were layers of sheet metal, with no real sealing or other glue holding them together (anymore?).
If they leak, I can imagine it being a "fluttery hissy" sound.
I noticed mine were gone because I heard an actual tick at WOT. Scared the bejeesus out of me... thought it was a plug.
Anyway, I can't really say one way or the other, on what to do with that "loose nut".
Try tightening it. Be CAREFUL. If it won't budge, it's not "loose" if you know what I mean
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #50 (permalink)
Old 04-04-2007, 05:17 PM
I hear ya on the be careful thing. I'm not usually such a woosey about such things but the prospect of breaking off a stud just doesn't do much for me. I'd rather be pulling the toy hauler around than spending a week doing what you did. At least I don't want to be forced into it.
So I'll give it a try. I'll try to back the nut off a little and see if I can get it to twist up tighter against the manifold. If it breaks, I'm going to be bummed.
__________________
  #51 (permalink)
Old 04-04-2007, 05:34 PM
Krewat's Avatar
Quote:
In all honesty, if it does break, drill it and use an easy-out on it, and replace the one stud.
And wait for the next one (if ever).
Most of mine would NEVER have had a problem. Certain ones were SHOT.
If you're lucky enough to have only one go bad, fix it before the leak gets really bad.
I would rather do one broken stud with an easy-out, than remove the whole thing to put a pair of vice-grips on it
By the way, don't take the long elapsed time for this job as being it's really going to take someone else that long. I'm milking it for all the "alone" time it's worth. And the off-center drilling on that one broken stud that broke below the surface of the head? Beer induced...
__________________
  #52 (permalink)
Old 04-04-2007, 07:04 PM
metalman1320 metalman1320 is offline
metalman1320 is starting off with a positive reputation.
Quote:
Ah Ha!! I knew alcohol was involved!! Why else would someone get this excited about having to change exhaust manifold studs on a V10 and drag it out for weeks!!
Did I miss it, or have you decided whether or not to wrap your headers?
Keep up the good work Art. I'm thoroughly enjoying this thread!!
__________________
04 F350 XLT 4X4 SRW SC SB V10, factory 4:30's, 2.5" leveling kit, Bilstein's all the way around, 315/75R16 Cooper SST's, BSEG's every time I plant my right foot.
Mid-Atlantic Smallies......catch, photo, immediate release....."We don't just encourage it, we live it."
  #53 (permalink)
Old 04-04-2007, 08:06 PM
sewerat's Avatar
sewerat sewerat is offline
sewerat is gaining momentum as a positive member of FTE.
When I bought my EX it had 4 broken bolts and would not pass a saftey or an E_Test so i had to get it done right away. I had the local shop in town do it for me and the total bill to do the job was about $1200 can. What they did was to weld a special kind of rod(don't ask I don't know what kind) onto the broken studs. Some were broken inside the block and some were broken outside then grab them with the vice grips and the walked right out easy. I think by the time they had the manifolds off they had to weld to 6 or 7 studs, then replaced them all with the new upgraded ford TSB parts. $300 worth of bolts mind you but they should last for awhile now.
__________________
2000 Excursion 4x4 XLT V10
K&N Filter, Flowmaster 40, Superchips Tuner, Bilsteins, Lift in near future
239.6 rwhp, 330.2 rwtq
2002 FLTRI Sewerats Site
In memory of my boy Duke. The K9 in the K9 Unit
http://home.cogeco.ca/%7Ecsulyma/Dukes1.jpg
  #54 (permalink)
Old 04-04-2007, 08:30 PM
Krewat's Avatar
Excited? Because for $200, I can buy headers, sell the manifolds on eBay and ALMOST make my money back, considering I don't need to buy a stud set...
Wrap? Not considering it at this point... I think I'd rather button up any gaps in the wheel well, and possibly make sheet-metal shields for the underside of the headers to keep them from getting splashed on. Believe it or not, I do actually SOMETIMES get this thing very dirty...
Alcohol? Well, it was late in the day, needed to get SOMETHING done that day, so drilled straight through the bolt. I caught it so close that the threads are on the stud. But you can see through the gaps inbetween in one area. But still enough in the hole to keep a stud in there (and some cylindrical-lock loctite.
__________________
  #55 (permalink)
Old 04-04-2007, 09:25 PM
Dude, my stud was broken! I put the socket on the nut and turned ever-so-lightly and off it came. At first I thought the nut was turning but nope, the stud simply was hanging on by a thread. It's broken off at the head level so there's nothing to be gained by removing the manifold. So now I get to try a reverse drill bit and an easy out I guess. Any suggestions? Helpful hints? Is there a tool with a guide that I can drill a quick hole right through the center of the broken stud?
__________________
  #56 (permalink)
Old 04-04-2007, 09:32 PM
BTW - check out these headers on Ebay. They're less than $200 shipped. Are these for real? The gasket looks ok, not one of those paper ones.
http://cgi.ebay.com/ebaymotors/99-04-F250-F350-Ford-V10-Stainless-Steel-HD-Headers_W0QQcmdZViewItemQQcategoryZ33631QQihZ013QQ itemZ230112432007QQrdZ1QQsspagenameZWDVW
__________________
  #57 (permalink)
Old 04-04-2007, 09:34 PM
Krewat's Avatar
That's what I was thinking while I was doing mine. A nice little jig to pass the bit through. If none exist, the potential for inventing one might be something to consider
The only thing I can think of is a center-punch that is the diameter of the hole. I remember my friend the machinist having those, and thinking "wow, that's perfect for bolt-broken-off-in-the-hole". As long as you have a straight line of sight, and a center-punch, you should be able to start in the middle and not creep too far out of whack.
I'll say one thing, I used a regular drill bit, not a left-handed one. Even the cleanest studs were pretty tight, almost an interference fit.
I hesitate to mention what size bits and easy-outs I used for fear that it's not the "correct" thing to do and screwing you up, especially as you're "down in the hole" so to speak.
__________________
  #58 (permalink)
Old 04-04-2007, 09:42 PM
Thinking about it, I'm just going to put another bolt on the drill press and cut a hole straight through the middle. That ought to be a pretty good guide. The only thing I'm worried about is if a drill will fit in the engine compartment... might have to go out a get a little 90 degree pneumatic just for this job.
__________________
  #59 (permalink)
Old 04-04-2007, 10:01 PM
Krewat's Avatar
I was lucky - I got my Ryobi cordless 18V in on the driver's side (rear-most bottom bolt).
The passenger side? Had to jack up the engine as far as the tranny dipstick would let it. And beyond.
But again, bottom rear-most hole.
Which one broke?
__________________
  #60 (permalink)
Old 04-04-2007, 10:08 PM
Antelope V-10 Antelope V-10 is offline
Antelope V-10 is starting off with a positive reputation.
I have a couple of different sets of these. I have never used them though.
http://cgi.ebay.com/NEW-Craftsman-Dr...QQcmdZViewItem
Do thing they would work? They come in different sizes too.
__________________
'03, V-10, Auto, XLT, CC, SWB, 4x4, 4.30's Truetrac, Doug Thorley Headers, Rancho 2.5" Leveling Kit, F-350 4" Blocks, Rancho RSX Shocks, Fabtech Adjustable Trac Bar, Avon SXT All Terain 285's, Banks Intake, Magnaflow Catback 15869, '08 Rear Diff Cover, 5Star 87 Perf. Tune
Tags
2002 , 68l , bolt , broken , drill , excursion , exhaust , f250 , ford , manifold , problems , remove , stud , studs , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
