Max tire size on a non-lifted F350 SD
Thanks to all that replyed to my last question about the FM mufflers. looks like i'll be checking other manuf. for their products. next question: what woud be the max tire size i could install on the 03 f350 sd with no lift kit? i was thinking Mickey Thompson MTZ in the 33 to 35 range. would hate to purchase and find out they rub. thanks again for all the help.
The following users liked this post:
I have heard of guys sqeezing 305/75/16's on stock wheels with no lift. I have LT285/75/16 Dick Cepek FC-2s and they fit very well with no lift and stock wheels. Dick Cepek and Mickey Thompson tires are made by the same manufactuer. The FC-2s I got have 5/8" tread depth which really help the tire bite the tradeoff is they howl some on the road.
I just put 325/60/18's on 18x10 rims on my 2000 F350 with no lift. I used 1/4" spacers behind the bumper and zip tied the back of the fender liner for a little more room while turning. No rubbing and it looks great. I'm still going to lift the front 1-2" but for now it works good. 325/60/18's are listed as 33x13, but are closer to 34" tall.
I am also interested in this question. I have a 2004 F350 single wheel 4x4. I already know that I shouldn't go bigger than 285/75/16 on my factory 16 inch rims. But I was wondering if a guy went to a bigger rim if he could use bigger rubber without getting a lift kit.
The diameter of the tire doesn't change just because you change the wheel diameter. There's no reason you couldn't put a 35" tire on the stock rims.
I ran the Goodyear silent armor 305/ 70/16 on my 03 f350 v10 on the stock rims for a few years (i know rim is too narrow) (i had 3 kids ages 3,1 1/2,and newborn) budget was tight then, no moving bumper or valence trim,inner fender pull back needed. I just ran pressures 45 psi front/40 psi when unloaded which was 99.8% of the time they wore very evenly (suprising) have 35,000 miles on them. And still have 40% tread left. Kids are older now (11,9,6) so for the last 3 years I've been sporting the 8" lift ,365/75/16 (38x14x16) km2's,on 16x10 ion alloys, but back then I had to do what I had to do to get a little more rubber under the truck (without the wife noticing) you all know how it is.
