Max tire size on a non-lifted F350 SD - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 03-20-2007, 04:24 AM
craneop craneop is offline
craneop is starting off with a positive reputation.
Question Max tire size on a non-lifted F350 SD
Thanks to all that replyed to my last question about the FM mufflers. looks like i'll be checking other manuf. for their products. next question: what woud be the max tire size i could install on the 03 f350 sd with no lift kit? i was thinking Mickey Thompson MTZ in the 33 to 35 range. would hate to purchase and find out they rub. thanks again for all the help.
Old 03-20-2007, 08:38 AM
birddog16 birddog16 is offline
birddog16 is starting off with a positive reputation.
285/75/16 are the largest that will fit a stock 03 F350 on stock rims. I had that size on my 03 and it would just touch the fender liner when off road.
Old 03-20-2007, 09:14 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I have heard of guys sqeezing 305/75/16's on stock wheels with no lift. I have LT285/75/16 Dick Cepek FC-2s and they fit very well with no lift and stock wheels. Dick Cepek and Mickey Thompson tires are made by the same manufactuer. The FC-2s I got have 5/8" tread depth which really help the tire bite the tradeoff is they howl some on the road.
Old 08-25-2010, 07:42 PM
Davetheicon Davetheicon is offline
Davetheicon is starting off with a positive reputation.
I am also interested in this question. I have a 2004 F350 single wheel 4x4. I already know that I shouldn't go bigger than 285/75/16 on my factory 16 inch rims. But I was wondering if a guy went to a bigger rim if he could use bigger rubber without getting a lift kit.
Old 08-26-2010, 09:14 PM
bigseadaddy's Avatar
bigseadaddy bigseadaddy is offline
bigseadaddy is starting off with a positive reputation.
I run 285/75/16 on a 4x2 F250 with no rubbing or issues my buddy runs 305s on his 350 4x4 with no issues both on stock rims. Both sets of tires are E rated. I do not think you could go any bigger then the 305 on the stock rim.
Old 08-27-2010, 08:35 AM
Oregon F350 Oregon F350 is offline
Oregon F350 is starting off with a positive reputation.
I just put 325/60/18's on 18x10 rims on my 2000 F350 with no lift. I used 1/4" spacers behind the bumper and zip tied the back of the fender liner for a little more room while turning. No rubbing and it looks great. I'm still going to lift the front 1-2" but for now it works good. 325/60/18's are listed as 33x13, but are closer to 34" tall.
Old 08-27-2010, 07:20 PM
sledhead03 sledhead03 is offline
sledhead03 is starting off with a positive reputation.
Quote:
The diameter of the tire doesn't change just because you change the wheel diameter. There's no reason you couldn't put a 35" tire on the stock rims.
Old 08-27-2010, 08:20 PM
dkf's Avatar
dkf dkf is offline
You can put a 315/70R16 on a stock rim however the wheel is way under the recommended width range. Tire wear and handling may be issue. The stock wheel is actually narrower than recommended for the 285/75R16.
Old 08-28-2010, 04:29 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
Yeah, 35" is 35" is 35" regardless of whether it's on a 16" wheel, a 17" wheel or a 20" wheel (or any other wheel). It will fluctuate slightly based on the width of the wheel (8" or 10" wide), but only slightly (maybe .5").
Old 04-23-2014, 01:30 PM
brianthecoug brianthecoug is offline
brianthecoug is starting off with a positive reputation.
Does anyone have this answer for a E99 F350. I am debating a leveling kit but would wait if I can get 285/75 on my stock wheels.
Old 04-23-2014, 02:55 PM
kas83 kas83 is offline
kas83 is starting off with a positive reputation.
285s on stock wheels here, not a single issue. I've seen many sets of 315s on stock wheels as well, no rubbing. I wouldn't recommend that, but they do fit.
Old 04-23-2014, 10:16 PM
ot106 ot106 is offline
ot106 is starting off with a positive reputation.
I ran the Goodyear silent armor 305/ 70/16 on my 03 f350 v10 on the stock rims for a few years (i know rim is too narrow) (i had 3 kids ages 3,1 1/2,and newborn) budget was tight then, no moving bumper or valence trim,inner fender pull back needed. I just ran pressures 45 psi front/40 psi when unloaded which was 99.8% of the time they wore very evenly (suprising) have 35,000 miles on them. And still have 40% tread left. Kids are older now (11,9,6) so for the last 3 years I've been sporting the 8" lift ,365/75/16 (38x14x16) km2's,on 16x10 ion alloys, but back then I had to do what I had to do to get a little more rubber under the truck (without the wife noticing) you all know how it is.
Old 04-25-2014, 08:13 PM
the cleaner's Avatar
the cleaner the cleaner is offline
the cleaner is starting off with a positive reputation.
2 inch front leveling kit got me 35/12.50/20 on my truck, room for bigger
Old 06-04-2014, 05:44 PM
captfatboyf250's Avatar
captfatboyf250 captfatboyf250 is offline
captfatboyf250 is gaining momentum as a positive member of FTE.captfatboyf250 is gaining momentum as a positive member of FTE.
Running new 305/70/16 on the stock rim fits nicely ,,,but will it effect anything as in running ,speed or anything else?
Old 06-05-2014, 12:06 AM
dkf's Avatar
dkf dkf is offline
Going up to 33" tires from the stock 32" tires actually made my speedo closer to accurate mph. Ford sets the speedo to read fast from the factory. I have checked with 2 GPS units and got the same result, right on.
I need a quiet tire! Dogmann 1999 to 2016 Super Duty 15 09-27-2014 06:25 PM
Mickey Thompsons for stock 1996 F350 jerrymlr1 1987 - 1996 F150 & Larger F-Series Trucks 3 07-20-2014 08:37 PM
Mikey Thompson Tires pin8246 1999 - 2003 7.3L Power Stroke Diesel 7 06-08-2014 09:25 PM
Tyre help for an Aussie WA F250 1999 to 2016 Super Duty 0 01-14-2014 07:35 AM
8 or 10 inch wheels? BoostRetard 1999 to 2016 Super Duty 16 05-27-2007 12:26 AM
Tags
2002, 2004, 2008, 2857516, 350, f350, fit, ford, lifted, max, options, size, stock, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
