Max tire size on a non-lifted F350 SD - Page 2 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 06-05-2014, 10:52 AM
ot106 ot106 is offline
ot106 is starting off with a positive reputation.
Captfatboyf250 glad to hear you got some bigger rubber just watch your tire pressure don't run them at max unless you're fully loaded (to avoid running on just the center portion of the tire) I usually chalk the tire tread (unloaded) and drive 100 yds in a flat parking lot and check tread (chalk) to assure the complete tread is contacting the road surface. On my truck when I had the 305's I ran 5 lbs less in the rears to ensure both front and rear tire treads were contacting the road surface make sure to chalk 1 front and 1 rear to see what pressure works best for yours for my current 38's on 16x10 rims (unloaded) I'm running 40 psi front and 35 psi rear. I have the v10
Old 06-05-2014, 11:23 AM
captfatboyf250's Avatar
captfatboyf250 captfatboyf250 is offline
captfatboyf250 is gaining momentum as a positive member of FTE.captfatboyf250 is gaining momentum as a positive member of FTE.
Dk ...like your girlfriend ie your icon
Ot I should have but would not of thought of that old circle track trick
Man big thx I will definitely ad that to our next pre flight (chalking)
Btw with the larger tires I did have to change the toe in/out quite a bite
Because compared to the 265 tracking it was all over the road ...
Checked ball joint connecting rods all rock solid, my have a little play in steering
Box ,,,hope this is adjustable....?
Old 06-05-2014, 12:30 PM
that tracking issue could have been over inflated tires writing on the center of the tread creates the same symptoms
Old 06-05-2014, 12:32 PM
Chalk them and check them before searching for a problem you didn't have prior
Old 06-05-2014, 12:33 PM
that was supposed to say riding on the center of the tread never had anyone during issues with mine once I chalked the tires and pressurized them correctly
Old 07-24-2014, 02:08 PM
ford_drive_one ford_drive_one is offline
ford_drive_one is starting off with a positive reputation.
31 A/ts
I have a set of 31 inch General a/ts on my stock rim no lift, '99 F-250.
Old 08-16-2014, 10:11 PM
Dogmann Dogmann is offline
Dogmann is starting off with a positive reputation.
305-70-18's AT on my 2008 F350.... Stock
I need a quiet tire! Dogmann 1999 to 2016 Super Duty 15 09-27-2014 06:25 PM
Mickey Thompsons for stock 1996 F350 jerrymlr1 1987 - 1996 F150 & Larger F-Series Trucks 3 07-20-2014 08:37 PM
Mikey Thompson Tires pin8246 1999 - 2003 7.3L Power Stroke Diesel 7 06-08-2014 09:25 PM
Tyre help for an Aussie WA F250 1999 to 2016 Super Duty 0 01-14-2014 07:35 AM
8 or 10 inch wheels? BoostRetard 1999 to 2016 Super Duty 16 05-27-2007 12:26 AM
Tags
2002, 2004, 2008, 2857516, 350, f350, fit, ford, lifted, max, options, size, stock, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
