Lug-nut torque for '02 F-150
This is a silly question, but I had to ask. I just rotated the tires on my '02 F-150, what the heck is the recomended torque for the lugs. I worked in a tire shop for a couple of years and I'm no stranger to doing a roto. We always torqued late model 150's to 100#'s. I noticed it even was marked on the lug-nuts(the flat washer part)100ft lbs. On my truck, I noticed the lugs had 150lbs stamped on them. They didn't seem that tight when I took them off, what gives? Did Ford change the spec?
NO clue. But common sense says 150 is too much. I torque all my cars and trucks to 100 pounds, regardless of wheels, studs etc. That is much better than your average shade tree mechanic who will torqe them 'snug' by feel in absence of a torque wrench.
Cheers, George
Cheers, George
Thanks Raceguy! Your right. According to the Discount Tire Co.'s 2002 application guide; see lug for tourque. I knew almost all F-150's were torque at 100#, but it's good knowing it was torqued right. I never would have guessed 150#, heck we only torqued 1-tons to 140#!
