how much do flex plates normally cost from a junk yard...
Typically not an item that you can get from a yard. They sell the engines complete with flexplate nowadays,and do not like to pull parts from them. Autozone lists a new one for $54.Dealers shouldn't be much more than that-I'm pretty sure the last one I got at the dealer was around $65. All you need is one for an F150/Expy 4R70W with an 8-bolt crank.
JL
That's not bad where can I get the lower plastic intake from. I can't find anywhere but from dealer for about 400$
That's about it-unless you find a yard that has a core engine lying around that they would want to part out.Possibly ebay-I see intakes on there from time to time.
JL
Thanks... I've ran into so many problems with this swap I may just wait till 75 dollar engine week at harry's to get the 4.6 from some cv there is plenty cop cars there... I'm tired of this job allready I want to drive how is the 4.6 for towing garbage or can I tow some stuff...
I used the pull a 30ft travel trailer that weighed a max of 6500lbs with the '98 F150 in my signature. It had 200K miles on it,and handled it without much fuss.
hehe..here's a pic I shot when pulling that trailer down the interstate on a road trip a couple of years ago...
It should-just swap the external accessories and the intake,etc. There were 2 different torque converters used on CV's though. One was a 12" and the other was an 11.25" converter,and the flexplates were different between the two. The flexplate for the 12" will fit you truck converter,the 11.25" flexplate will not.
JL
