View Poll Results: What type of gas?
I run Regular, and have no pinging.
101
70.63%
I run Regular, and have occasional pinging
29
20.28%
I run higher octane gas because it stops pinging
6.29%
I run higher octane gas because I wouldn't put anything less in my megabuck truck.
2.80%
Voters: 143. You may not vote on this poll
Premium vs. Regular in a V10
I've only ever put regular (87octane) in the tank... but on this last recent trip I noticed 86 and even 85 octane at some of the pumps.... Anybody use them? any problems? if it saves money and the truck don't mind, then I sure don't either... I should have tried a tank, but it was mostly - fill the tank, drive til it's gone, fill the tank, repeat.... and I didn't want to take the chance of a full tank of something that might hurt the engine...
I have always used 87 octane on my stock vehicles. Anything more is a waste.
In the early to mid 90's, I was heavy into modifying Fords, mainly mustangs. I remember most of Ford's engine control systems had knock sensors. That allowed the computer to advance the timing and take advantage of the higher octane. Same thing with distributors. If you advanced the timing you could make noticeably more power with higher octane.
Do our V10 engine control systems use a knock sensor? I am not sure, but if it does, you would gain something from using higher octane.
87 octane, no ping. We run the 10% ethanol stuff here on Long Island - I believe it's year-round.
Yeah, the V10 does have a knock sensor, actually.
Which is why it's so weird when I hear stuff like this.
Over the years I've been in this forum, I've read just about every post.
I can say this. There are a small number of those who's V10 pings. Most never do.
Sometimes it's the bellhousing cover rattling, sometimes it's an exhaust heat shield. The V10 throws off some weird vibrations sometimes.
There are those who reset their PCM (computer) and it goes away for a long time. These seemed to be somewhere in the 2000-2002 range, I think. Maybe even just 2001. To me, that's a bug in the software.
And then, we come to the final set of people, VERY small number, whos V10 pings. No matter what, it pings on 87 octane. They have to go to 91, and even 93 sometimes to get it to stop.
And I don't think they ever cure it, or at least we've never heard back from them ... maybe that's a good thing.
But first things first.
1) Reset the PCM - easiest to do, and you don't even need to pay for it Drive it for a week, or at least 100 miles or so. Did the pinging go away?
2) Try 93 octane. Run the tank down as far as you feel comfortable, until the low fuel light is on, and then put 10 gallons of 93 in it. Run it for a few hours. Does the pinging quiet down or go away completely? If so, this is a compression/octane issue.
3) If the pinging still doesn't go away, it's not a ping. Or, it's not a ping caused by compression/detonation. Like a wrist-pin. Or piston slap.
Oh, and by the way, when does the pinging occur? Half-throttle? Full-throttle? All the time? Certain RPMs, what?
Originally Posted by pfb
How do you reset the pcm? I'm guessing unhook the battery for 1/2 hour or so.
After that, you should do the OBD-II "readiness" driving cycle, which is basically just normal driving, half stop-and-go, the other half highway driving. Check your owner's manual, you'll find the procedure. It doesn't have to be strictly adhered to (some people find it hard to go 65MPH on the highway and then coast to a full stop)
Last week I got a tank of AM/PM (Arco) reg. gas in my 00 V-10 and it pinged a little, this was the first time in its life it pinged, I added a bottle of octane bust and 1/4 tank of the good stuff and it went away.
This gas was also cheaper, by 15 cents than the other stations, on the other corners, and Im convinced its cheep low octane gas. Gas in Calif. is running from $2.95 to $3.30 per gal in most places, about $3.06 on avg. Higher closer to the interstates.
No more Arco reg for me.
Originally Posted by Big Orn
I wonder if it's actually a "timing" event or if it's something altogether unrelated that we're reading so much about? Can't say since I've never heard any Triton engine "ping".
Whenever I hear about this, I immediately think "EGR" but the fact that most V10's don't have them precludes that.
Regular maintenance first:
Fuel filter.
Clean MAF.
Check for vacuum leaks.
Check fuel pressure - both under load AND idle! Check fuel regulator operation.
And as always, try 93 octane and see if it reduces or eliminates it. If it does, that points at ignition/compression.
