#1 Cylinder location on 2003 F150 4.6L - Ford Truck Enthusiasts Forums
Old 03-18-2007, 12:50 AM
billti billti is offline
billti is starting off with a positive reputation.
Where is the #1 cylinder on a 2003 Ford F150 4.6L engine located? Is the diagram below correct?
Back of truck - - Driver side 2-4-6-8 - Front of truck
Back of truck - - Pass. Side 1-3-5-7 - Front of truck
So the #1 cylinder would be Back right side corner of the engine compartment?
Old 03-18-2007, 02:05 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum
4 8
3 7
2 6
1 5
Front
It's the front passenger side.
Old 03-18-2007, 11:49 AM
Thanks for the cyl. location information Lxman1
I recieved a CYL #1 misfire code and was changing the spark plugs and checking for condensation in the spark plug wells.
I was going to change spark plug #1 first and then try it to see if it corrected the misfire but I wasn't sure where #1 was.
Bill T.
Blown #3 Plug on 4.6 engine. 2003. 8 burnin 2 turnin 1997 - 2003 F150 14 09-01-2015 12:58 PM
2007 4.6L #8 cylinder misfire hunt1moore Modular V8 (4.6L, 5.4L) 4 09-01-2011 06:38 AM
Romeo 4.6 tick (TSB 03256)--timebomb? YoGeorge Modular V8 (4.6L, 5.4L) 12 08-27-2008 11:02 AM
4.6L cylinder numbering johnfretz Modular V8 (4.6L, 5.4L) 1 08-05-2004 09:43 PM
Cylinder Number Layout 2000 4.6L V8 oddsix 1997 - 2003 F150 3 12-18-2003 05:49 PM
Tags
03, 1, 2003, 2005, 3, 46, cylinder, diagram, engine, f150, ford, location, numbers, order, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
