Connectors under steering column - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 03-17-2007, 08:56 PM
Ratpack Ratpack is offline
Ratpack is starting off with a positive reputation.
I was under the dash this weekend and noticed there are a couple connectors under the steering column that are not connected to anything. One is even hard mounted to the bottom of the trim panel facing out toward the driver. Anyone know what they are there for?
Old 03-19-2007, 12:26 PM
03GrnEBExpy 03GrnEBExpy is offline
03GrnEBExpy is starting off with a positive reputation.
The connector that is facing out towards the driver is for the techs to plug in diagnostic equipment. This is also where you would plug in an aftermarket power programer. As for any others they may be for uninstalled optional items. If you have a factory trailer tow package there will be a female plug end where an aftermarket electric trailer brake controler would plug in.
Where is airbag diagnostic connector? exranger06 1978 - 1996 Big Bronco 1 12-02-2013 04:46 PM
steering column electrical connections nbafreak2007 1997 - 2003 F150 1 01-08-2009 03:56 PM
What is the green connector below dash on steering column?? katdaddy Explorer, Sport Trac, Mountaineer & Aviator 2 02-23-2006 10:11 AM
Under dash connector jharvey3 1999 - 2003 7.3L Power Stroke Diesel 0 11-01-2003 03:06 PM
Curved connector on a 78 Ford Truck steering column. 1968F250LWB 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-13-2002 09:27 PM
Tags
2004, 2009, column, connector, connectors, f150, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
