how to lower the rear end? - Ford Truck Enthusiasts Forums
Old 03-17-2007, 03:27 PM
Jeff-150 Jeff-150 is offline
Jeff-150 is starting off with a positive reputation.
i put some new tires on my 95 f-150 yesterday and they look great (275/60/r15). but, i dont like how much fender well shows in the back. the front is fine. i don't want my truck to be too low, just leveled. i cant seem to find lowering rear leaf springs.
Old 03-17-2007, 03:55 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
I take it you have a 2x4 . How much you need to go? You can get 2" lowering shackles . Remove a leaf spring or 2. Put custom block under spring that is thinner. Or run around with weight in back of bed. HaHa
Keep us posted.
Old 03-17-2007, 07:46 PM
TommiFIN TommiFIN is offline
TommiFIN is starting off with a positive reputation.
Who makes/sells 2" lowering shackles? I also would like to lower my ´89 F150 a little.
Old 03-17-2007, 08:01 PM
I don't know but have seen them on eBay last week and in sports truck magazine while back. I'd check with any of the sport truck suspension company.(lowering kits )
Old 03-17-2007, 08:42 PM
bigredneck47240's Avatar
bigredneck47240 bigredneck47240 is offline
bigredneck47240 is starting off with a positive reputation.
i have a question that deals with this i have a 4.2l 4x2 lon wheel base truck and would like to raise the front to level the truck out im a redneck and usually im found off road somewhere so i dont want to lower it. is there any cheap ways i can do this. maybe my next truck will be a 4x4 and i dcan jack it up but im stuck with this one till i get it paid
Old 03-18-2007, 06:36 AM
lostin90s: I´ll try find them from ebay,thanks.
bigredneck47240: BroncoGraveyard sells 2" poly lift spacers,they cost 95 dollars. There´s also new stiffer/longer front coil springs for sale.
Old 03-18-2007, 10:03 AM
thanks man i appreciate it
Old 03-18-2007, 11:14 AM
92F150Flare 92F150Flare is offline
92F150Flare is gaining momentum as a positive member of FTE.
LMC truck, Summit racing, Jegs, JC Whitney.. all on-line catalogs....I've seen kits at AutoZone too........the 2 inch shackle drop is really common.
If you're broke.....take a torch to the front 6 inches of the spring and let the truck settle......cheap and fast.
Good Luck
Old 03-18-2007, 05:56 PM
F250Tech F250Tech is offline
F250Tech is starting off with a positive reputation.
Quote:
coil spring jacks or change coil springs to 3/4 or 1 ton springs and adjustable ball joint sleeves
Old 03-19-2007, 03:40 AM
Good Luck
I´ve searched them from summit before but I couldn´t find them but now I did.
Thanks for a tip.
Old 03-19-2007, 08:01 AM
wrenchturner wrenchturner is offline
wrenchturner is starting off with a positive reputation.
i would just google a drop shackle. heating springs isn't always a real good idea.
http://www.rpmoutlet.com/lightmagna.htm
http://www.stylinconcepts.com/part.a.../categoryid/30
Lowering a 2015 F150 chrome85 2015+ F150 7 05-26-2015 11:56 AM
How low is she? JHalvorsen 1973 - 1979 F-100 & Larger F-Series Trucks 14 04-27-2015 10:16 PM
lowering kit for 2wd f150 5.0STX 2009 - 2014 F150 33 12-18-2014 01:13 PM
Slamming a 72 f100 f100T 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-18-2014 07:33 PM
Proper way to lower 96 F150 Ron Brakes, Steering, Suspension, Tires, & Wheels 5 07-15-2001 08:43 PM
Tags
2007, 250, end, f150, ford, lower, lowering, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
