O2 sensors... How many? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-17-2007, 02:47 PM
louiss4618 louiss4618 is offline
louiss4618 is starting off with a positive reputation.
Smile O2 sensors... How many?
Hi all,
I have a 2001 Ford Escape with the 3.o V6.
My for some reason the other day my escape blew a hole in the side of my EGR valve, somthing I have never seen done before. Took it to my mechanic and he found that my convertor was clogged and the insides melted. I ordered a new convertor and egr valve for him to replace.
he also suggested that I replace my o2 sensors. My question is how many are there and does anyone have part number form any place for these?
From what I read and seen there are 4 total but not sure when it comes to ordering.
Also where would I find and EGR tube? I read that that should be replaced when repalceing the EGR valve.
Any help would be great.
I have found this forum helpful in the past with a couple of other problems I have had with my escape.
Old 03-30-2007, 11:15 PM
Tired_Escape_Driver Tired_Escape_Driver is offline
Tired_Escape_Driver is starting off with a positive reputation.
The egr tube is the pipe that runs from the exhaust manifold up to the egr valve. mine did the exact same thing btw. i did not replace the egr tube even though ford recomends it. It has pipe style threads on it that are quite tricky. but if your careful. or in this case. your macanic is careful. you will have no problems. You should look into replasing the Egr Position sensor. IMO. mine got blown away when my cad converter finally plugged.
Old 08-16-2008, 12:14 AM
mrfix71 mrfix71 is offline
mrfix71 is starting off with a positive reputation.
2002 Blown Out EGR vales
I have the same problem with EGR valves blowing out the side (4 times in less than a month). I temporarily blocked the hole with putty which blew up the intake manifold that afternoon. Dealership repaired that.
Two weeks later another EGR blew out. The dealership said "all of the catalytic converters are clogged" and are 7,000 miles past the warranty. They printed out a diagram of the exhaust system and also demonstrated how they test the exhaust backpressure. It seems the exhaust manifolds are also converters for a total of three catalytic converters and 4 H2O sensors......and each one is expensive. Total repair cost would be about $3,500 to replace the converters!
It would be a pain to swap out the manifolds myself and expensive to replace everything. Has anyone looked at the manifolds or know if they could be clogged? I temporarily punched out the rear converter to get the thing driveable, but I do not trust it.
The part numbers for the O2 sensors on my diagram are 9f472a, 9f472b, 9g444a, 9g444b.
2004 escape limited Catalytic convertor repair crashmccash Escape & Escape Hybrid 2 04-24-2015 09:35 AM
2008 Escape Code P0400 EGR valve pk64f100 Escape & Escape Hybrid 0 12-04-2014 03:44 PM
2006 Ford Escape XLT/225,000 miles MaryG1959 Escape & Escape Hybrid 10 09-13-2013 08:44 AM
2007 ford escape egr valve tom carry Escape & Escape Hybrid 2 12-15-2012 12:30 AM
94' crewcab 351w running rich, black smoke. Beastlyforddude 1987 - 1996 F150 & Larger F-Series Trucks 21 08-05-2010 02:41 PM
Tags
02, 2001, 2002, diagram, egr, engine, escape, ford, forum, location, melted, o2, sensor, sensors, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
