Standard SEVEN WAY plug wiring diagram
#31
Problem is, an RV battery is a deep discharge battery whilst a truck battery is NOT. If you hook a deep discharge battery directly to your trucks 12v system and LEAVE it there, you can (and will) kill it by boiling the water out.
You need to go thru a devise that will limit the charge cycle...... or carefully watch the charge with a hydrometer or voltmeter and when it gets charged, disconnect it.
#32
Old thread I know, but..
If your alternator is working correctly it essentially stops charging when a battery is fully charged.
The longest lived battery I've ever had was a Sears Diehard wet cell deep cycle installed as the only battery in one of my Land Rovers. It lasted close to 10 years.
I used of for starting and for winching.
#34
I’m trying to get my wiring straightened out. The trailer lights work great when hooked up to my Pathfinder and all the lights work correctly on my F250. When I hook the trailer to my F250 everything works but the right blinker light. Trying to diagnose. I did find the blinker wire in the tail light plug and I’ve spliced in a wire that I’ll connect to the seven pin connector if I cants find the problem. Anyone with any suggestions, I’m all ears!!
ChevyExterminator
07-05-2021 12:17 PM
Ethan Campbell
09-30-2020 06:25 PM
Vinford
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-11-2014 12:50 AM
DetailerDave
28
09-18-2013 01:09 PM
