Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-16-2007, 07:31 PM
live2hunt live2hunt is offline
live2hunt is starting off with a positive reputation.
Removing window tint glue?!
Just peeled off the old crappy window tint with little difficulty.
However, how in the heck do you get the glue off?!
Acetone? Laq thinner? Heat gun?
__________________
2001 F-350 CREW CAB W/7.3L
  #2 (permalink)
Old 03-17-2007, 10:32 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all FTE Trigger is a name known to all
ammonia...seems to eat it off.. I personally like windex and some of the Cheaper ones you can find at the Dollar store....
-Tape/cover...and anything else you can do to protect the door panel (remove if its easy enough)...
-Squirt the window down really well
-use a single edge (scraper type) razor
**Tip**The solvent will act as a lubricant for the razor to prevent you from scratching the glass... If a spot starts drying up, re-spray it... (you should Not hear any scraping noises from the razor)
The old glue should clump together as you scrape....have a towel/trash pile-can ready
On Edit: I normally use 3-5 New blades per "avg." sized side (drvr-pssngr) window.
__________________
-Rich
Chapters / 2004-2010 F150 / 2011 F100 Moderator
****Join the South Carolina Chapter here!!!***
..Or your own state chapter Here
  #3 (permalink)
Old 03-20-2007, 10:48 PM
GShelton's Avatar
GShelton GShelton is offline
GShelton is starting off with a positive reputation.
Just use straight ammonia in a spray bottle and work it with a razor blade. Just don't let the ammonia get on the interior. It may blotch the plastic.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
