Go Back   Ford Truck Enthusiasts Forums > Marketplace > Vendor Specials, Discounts, Product Announcements & Group Buys
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
  #1 (permalink)
Old 03-16-2007, 09:31 AM
DiscountPowerPrt's Avatar
DiscountPowerPrt DiscountPowerPrt is offline
Garage is empty, add now
DiscountPowerPrt is gaining momentum as a positive member of FTE.DiscountPowerPrt is gaining momentum as a positive member of FTE.
Intake Elbow 6.0L Stainless Steel
Stainless Steel! LINK
Smooth mandrel bent tubing -Polished -for use with factory 0-ring and intercooler piping -1/8" NPT threaded bung on rear for nitrous or a boost gauge fitting -The stock elbow has a sharp 90 degree lower inside angle, and a rough sectioned upper , which both restrict airflow.
Click the image to open in full size.
The orange lines in the picture above show what the stock elbow looks like inside. The picture below shows what is happening to the airflow inside the elbow. (Flow analysis was set up on both intake elbows with the exact same parameters.) Because of the sharp 90 degree turn on the stock elbow, note how all the airflow is bunched up at the rear. This means that approx 30% of the available inlet area (front portion) to the engine is useless. The average overall pressure drop difference (at the base of the elbow) between the stock and new elbow is approx 2 psi. This means that in order to achieve the same amount of boost at the engine, the turbocharger (and engine) have to work harder to overcome that pressure drop. With the stock elbow, this results in higher Exhaust Gas Temperatures, lower fuel economy, and more stress on the turbocharger.
Since the new elbow (below) has the smoothest possible transition through the whole elbow, the entire area at the bottom of the elbow is used.
Tags
60, elbow, ford, install, intake, polished
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
