FLEX O MATIC lowering
Old 03-15-2007, 11:40 AM
tonydlt's Avatar
tonydlt
tonydlt is offline
hey could i remove that flex o matic piece on the springs and install lowering shackle to drop it.
Old 03-15-2007, 02:12 PM
blatherskite's Avatar
blatherskite
blatherskite is offline
I believe you would also have to replace the springs. Flexomatic springs are longer than the 'standard' spring with one piece shackle.
Old 03-15-2007, 03:01 PM
68murc's Avatar
68murc
68murc is offline
My truck has the Flex-O-Matic suspension too. What was ever the idea behind that. What were the benfits?
Old 03-15-2007, 03:05 PM
blatherskite
Its basically an overload device that will stiffen the spring by shortening the active length once its loaded to a certain point.
Old 03-15-2007, 04:37 PM
68murc's Avatar
68murc
68murc is offline
ok, makes sense.
Old 03-15-2007, 05:08 PM
instig8r63's Avatar
instig8r63
instig8r63 is offline
Anyone got a picture of the "FlexO" and non?
Edit: Never mind I found some pictures of both.
What's the difference in the ride?
Old 03-15-2007, 07:45 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
No difference in ride, that is why they designed it.
It is almost up against the bottom of the bed so nothings
gained in the rear. If you invert the front hanger this will allow
for 4 1/2" higher pin location, divide by 1/2 that's your drop.
Trouble is your pinion angle will be altered and adding a wedge
will raise the back end slightly again.
steve340
05-05-2017 05:22 PM
C-700
01-10-2017 08:53 PM
FILTHY
28
07-26-2016 08:08 PM
SoCalExile
03-24-2014 02:59 PM
shift1313
33
04-23-2009 10:24 PM
Quick Reply: FLEX O MATIC lowering
