Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-14-2007, 09:58 PM
Murphy2000 Murphy2000 is offline
Garage is empty, add now
Murphy2000 is starting off with a positive reputation.
Check this out..
Impressive
http://www.sciencedaily.com/upi/inde...omassfuels.xml
  #2 (permalink)
Old 03-15-2007, 05:58 PM
mechmagcn's Avatar
mechmagcn mechmagcn is offline
Diesel Junky
1953 Ford F-100
mechmagcn has a good reputation on FTE.mechmagcn has a good reputation on FTE.
If it really works as said, they had better get it out in public before big oil companies and the politicians they own supress it in some way.
The oil companies just sit back and laugh at all of the attempts to find ways to supply fuel from sources besides oil, but so far no one has come up with anything that will significantly curtail our need.
__________________
Jeff
1953 F100 PU "Someday"
Lincoln Town Car front clip
5 cyl Mercedes turbo diesel/auto
It Runs! It Even Moves!
  #3 (permalink)
Old 03-15-2007, 09:06 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Duhhhh, how much energy does it take to produce Hydrogen? According to all the " professionals" alot. Why not just burn the hydrogen? We have been making moonshine for years. and my final skeptical and sarcastic comment is that gasification has been around since Hitler tried taking over the world and was running out of petroleum. But otherwise, it was a good, short article.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #4 (permalink)
Old 03-16-2007, 04:25 PM
Cool6.9DieselGuy Cool6.9DieselGuy is offline
Cool6.9DieselGuy is starting off with a positive reputation.
Quote:
Originally Posted by Murphy2000
Impressive http.....
ok now call me crazy but isn't this the same thing as hydrogenated oil??? Like hydrogenated vegatable oil you find in foods sometimes, the stuff w/ trans fat in it that they're trying to ban now because of how unhealthy it is? I think the main reason they use it is just like that article was saying too, because you can make a lot more of it cheaper. A huge majority of restaurants use hydrogenated oils in their fryers because it's so much cheaper, and a lot of guys use the WVO to run their trucks so it must still work like regular veg oil.
  #5 (permalink)
Old 03-19-2007, 11:59 PM
Here's the deal in layman's terms,
They've figured out how to create a biodiesel or alcohol fuel and artificially inject hydrogen to increase its energy content.
Hydrogen is easy and cheap to produce. It can come from many sources but our most common are electric and natural gas. Hydrogen can be pulled right out of water through electrolysis or obtained from natural gas by a process called steam reforming.
Electrolysis can come from any energy source including hydro, solar, nuclear, or wind as well as dirty sources like coal and others.
Natural gas is plentiful but injects green house gasses into our atmosphere.
Our capacity for wind generation of static power requirements is not even tapped yet.
Our dynamic requirements are all solved with liquid fuels because of the energy density factor. Liquid fuels are the way to go until we can come up with something even more dense like a solid. (they are getting there). One guy has a hydrogen gas tank that is the same size as a conventional car tank, weighs about the same and can store 50% more energy than the same amount of gas.. The problem? It requires amonia. Super dangerous in even small amounts.
Well, for now its gotta be biodiesel for me.
  #6 (permalink)
Old 03-20-2007, 03:52 PM
a lot of great ideas out there but still very impractical, hydrogentated biodiesel for your truck is cool though unlike hydrogenated veg oil to fry your food in
  #7 (permalink)
Old 03-20-2007, 06:39 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Lets get this straight. The proposed process is NOTaimed at producing hydrogenated BD. It is all fairly complicated and I am leaving a link to the paper written by the developers;
http://www.pnas.org/cgi/content/full...etype=HWCIT#T1
drink several cups of coffee before you start cause it is not guarenteed to keep you on the edge of your seat.
Lets see If I can explain in terms that do not require a PhD in Physical Chemistry.
The whole process is a modification and combination of existing processes.
First gassification of biomass is currently possible. It isn't complicated just heat any biological material untill it breaks down to its elemental components. Since the main components of biomass are carbon and hydrogen the primary products of gassification are carbon and hydrogen. At the temperatures needed to gassify carbon does not stay elemental rapidly combines with oxygen to form CO2 and CO while hydrogen combines with oxygen to form H2O.
Second there are existing processes for producing synthetic hydrocarbon fuel from CO and H2. You really dont want me to go into it cause it will require a book. Just accept that it can be done.
The problem with simply combining these two processes is that the CO2 produced in gassification is wasted carbon atoms because they cannot be converted to synthetic fuel. Of course CO2 is an undesirable effluent (greenhouse gas, global warming, etc )
The modification proposed is to flood the gassification processor with CO2 and H2. The extra H2 will consume some of the available O2 and the CO2 will inhibit formation of more CO2 thus driving the gassification to produce much higher levels of CO. The resulting gas stream wil contain CO (in high levels) CO2, H2, and H2O. The CO and H2 are used to make synthetic hydrocarbon fuel, the CO2 is sent back to the gassifier to keep CO2 levels high and the H2O is subjected to electrolysis producing O2 and H2.
By using this modification to current gassification processes production of CO is predicted to rise 40 to 50%. Thats how they propose to dramatically decrease the amount of biomass needed
If the energy source driving this whole scenario is noncarbon based ie: nuclear, solar, wind, hydro the greenhouse gasses will be dramatically reduced making this a viable process.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #8 (permalink)
Old 03-20-2007, 11:45 PM
wish I had the time
  #9 (permalink)
Old 03-23-2007, 01:11 AM
Phydeaux88,
From a broader perspective, isnt that what we've been after? Green energy is great, but none of it is a portable fuel like petroleum is. Hydrogen is very difficult to store and handle, biodiesel is great but can only take us fat americans so far.. Wind, solar and atomic all produce electricity.. Good for a home but not for transportation.
We need an energy source with an equal or greater energy density than the petroleum fuels we currently use.. In addition, it needs to come from a clean source.
I think these guys hit the jackpot.. a way to increase biomass energy output by a whopping 3 fold or more while keeping the same physical volume. The've figured out how to convert the hydrogen from green electricity to a liquid fuel by employing the use of a natural carrier media that burns clean.
Am I understanding this correctly?
Very interesting stuff..
  #10 (permalink)
Old 03-23-2007, 10:00 AM
wvoburner wvoburner is offline
wvoburner is starting off with a positive reputation.
Why not skip the whole BD process and just burn SVO? Perhaps that is just too simple. But, I am a simple guy.
P.S. I love this forum! It reminds me of the Boston Tea Party! Git-r-done!
  #11 (permalink)
Old 03-23-2007, 11:46 AM
Phydeaux88's Avatar
Quote:
Because burning WVO has its problems.
BD is safer.
__________________
  #12 (permalink)
Old 03-23-2007, 12:01 PM
What problems? I dont want to go down that road if BD is better -
  #13 (permalink)
Old 03-23-2007, 02:48 PM
In a clamshell, burning veggi produces a carbon build up behind the piston rings. Rings expand, cylinder gets hot, engine goes blah.
__________________
  #14 (permalink)
Old 03-23-2007, 07:56 PM
bummer ........
  #15 (permalink)
Old 03-24-2007, 12:20 AM
yea the BD is a lot healthier for an engine compared to svo or wvo
I hate to say it but hydrogenating the BD is really an outstanding idea, it's totally renewable, is not as hazardous as something like riding around w/ straight hydrogen in your tank(get in an accident and die instantly, lol), and it's probably not very harmful on the emmissions factor, it's probably got a lot of other pros that I can't think of right now. now we should just convert all of our electricity to windmills too.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
