Soft Brakes
Soft Brakes
Did you bleed both caliphers after putting in the new pads? Also how did you put the pads back in did you just push the piston back in and slap the pads on? If you did this you might have a leak at the caliphers. If you did bleed the front brakes try bleeding all four starting from the farthest away from the master cylinder and moving to the closest. Most front disc rear drum vehicles get their peddle from the rear brakes try adjusting the rear drums out till they just make contact with the drums judge this by lifting rear wheels off ground and putting truck in neutral and spin the wheels till you feel a little resistance. Hope this helps some and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Rick
