Supercharging the Navigator
Originally Posted by rpcarlson
I tow a 28' Airstream with my 1998 Navigator, 5.4 2v. I am thinking of supercharging it. Does anyone have experience with this. Also, I am considering buying a 2003 Navigator with the 32v engine, as a possible supercharging candidate instead. Thanks, Ron
JL
I have modified the Navigator engine with a Superchips program, which adds allot of advance, I believe. Also, installed is a free flowing Gibson muffler. These mods added allot of snap. I wouldn't consider swapping engines. If I stay with an unsupercharged 4v, I'll buy a 2003 Navigator, which has many desired improvements. Ron
JL
With the prices on used 2006's right now - I wouldnt consider an 03. There are used 06's selling for $34-37K. An 03 is gunna run you $22-25K.
The 06 gets you a slick 6-speed tranny, better fit and finish, the 3V engine (not really better than the 4V, but more supported by the aftermarket due to the F-150 crowd)
I have an 03 BTW so I'm not biased to the 06.
I tow a toy hauler about 7000-7500LBS with my 03 FX4 5.4 (2V)...It does fine on the flats and stop and go's but I feel the need for a little more on hills maybe only a 4-5 LB Boost would be perfect...So I would supercharge as I hope to soon..With a low boost your interanal parts will be fine.....
JL
Who is Kenne Bell? The 2003 Navigator has the 4v. The 2005 got the 3v. Thanks, Ron
I've got 135K miles on my Procharged 5.4 (35K of those miles with the supercharger).
10.5 psi peak boost, but less at lower RPM.
I tow a 7,000 lb boat thru the desert, it handles it very well.
If you want to supercharge it, make sure that your engine is in good shape (compression or leakdown test). Also, make sure you've got a good tune, you don't want the possibility of detonation while towing.
Jason Byars
10-18-2016 08:46 AM
