cruise control on/off switch - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-14-2007, 09:40 AM
gmitchell gmitchell is offline
gmitchell is starting off with a positive reputation.
Does anyone know how to remove the cruise control on/off switch on the steering wheel? The switch cover broke - I am going to try and glue it because I can't buy just the cover I would have to buy a new switch for $80!
Old 03-14-2007, 08:59 PM
Tired_Escape_Driver Tired_Escape_Driver is offline
Tired_Escape_Driver is starting off with a positive reputation.
my switch only works to turn the system on. i havent looked at it too much. but I wont be replacing it at 80 bucks... lol
Old 03-22-2007, 04:32 PM
rc581 rc581 is offline
rc581 is starting off with a positive reputation.
i just removed mine last night. mine is in a 2003 ranger. disconnect the battery and wait about 5 min. for residual voltage to dissipate. then right behind the steering wheel , there are 2 round openings with plugs in them, just pry the plug caps off and remove the 2 bolts, one on each side, lift the airbag off very carefully, disconnect it at the plug and set it aside. now the cruise switches are easy to take off. just pull the black plug off the switches very carefully and do what you need to do with it. the switch will come apart in 3 pieces. good luck and i hope this helps.....bob
Old 03-23-2007, 09:01 AM
Thanks for the info Bob. I will give it shot, I didn't think I would have to take the air bag off. I have a service manual but it doesn't give any info about the switches on the steering wheel.
Old 03-24-2007, 08:35 PM
its not too bad a job to do. as i said, be gentle with the air bad when you unplug it. it took me about 25 min. total to take it off, remove the switche and check the lamps and reassemble. just take your time and let me know how you make out good luck....bob
Old 03-29-2007, 08:45 AM
Bob you were right it wasn't too bad, it was a little more involved than your Ranger.
After removing the plastic trim around the column you can get to the 4 torx screws that hold another plastic trim piece just behind the airbag. Once that is removed you then have access to the 4 nuts that hold the wheel and airbag on.
I glued the broken on/off switch back together and stuck it back on.
Everything works fine and I saved myself $80 bucks.
Old 03-29-2007, 01:28 PM
great, glad everything went smoothly for you.....bob
Cruise on/off button SuperDutyScaler 1999 to 2016 Super Duty 2 12-08-2015 08:00 PM
Cruise control Superk401 1999 to 2016 Super Duty 3 09-30-2015 02:26 PM
Cruise control will not work or come on 2003 F250 BoydII 1999 to 2016 Super Duty 6 10-24-2014 07:56 PM
Speed Control Light alduane Ranger & B-Series 7 11-02-2008 05:44 PM
Cruise Control Switch Pod Light Bulb euforia51 Explorer, Sport Trac, Mountaineer & Aviator 5 05-07-2003 01:38 AM
Tags
2003, 2007, button, control, covers, cruise, davidson, escape, ford, harley, long, remove, steering, switch, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
