1999 F-350 V-10 to 7.3L Diesel - Ford Truck Enthusiasts Forums
Old 03-14-2007, 04:14 AM
f250rangerexplorer's Avatar
f250rangerexplorer f250rangerexplorer is offline
f250rangerexplorer is gaining momentum as a positive member of FTE.
Exclamation 1999 F-350 V-10 to 7.3L Diesel
Ok i know you guys are gonna tell me to buy a new truck or one with a diesel already in it but...... well this was my grandpa's truck and he left it to me when he passed away. It's a really nice truck and only has 108k and it has 3 coil packs bad, needs a tune up and it burns about 2-4 quarts of oil between changes.... so i wanna put a 7.3l powerstroke in it....
What do i need besides obveously the engine, does the wiring interchange and plug and play with the new harness or how do i go about the wiring....
I am really wanting to do this and have to do it within the next month or so if i'm gonna do it. i travel about 350 miles at least twice a month so the milage of the V10 is about 7-9.5 on the interstate and always has been since new. in town it's about 4-7 towing and empty 50/50. we got a ranch and small construction company so i got plenty of diesel... we got two 1000 gallons tanks at the ranch so it's also more convienient.
-So what do i need to do the swap???
Old 03-14-2007, 05:22 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
Quote:
Yep!!
The first thing your going to need is around $5,000-$8,000 for parts or for a good parts truck
Well, it would probably be easiest to find a rolled truck with what you want and drop your cab and clip on it. The newer the truck, the tougher the swap
Someone more knowledgable than I will chime in here shortly
Old 03-18-2007, 04:37 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
The good news is the V10 and Diesel share the same subframe components. Buying a Powerstroke engine alone will set you back about $6K, then you need a tranny, at $2500. On the other hand you can find a V10 for about $2500.
Try searching Ebay and you might find a wrecked truck and you will have all the parts you need.
Old 03-19-2007, 10:05 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
MODERATOR--- MOVE THIS TO THE 7.3L FORUM
OR----
O.P. re-post this ? in the 7.3 forum, there are a lot of smart people there, that love a challenge.
About to Buy My First Truck !!!!! Advice Please PWJE 1999 to 2016 Super Duty 31 11-21-2013 05:23 PM
'01 F350 7.3L front end is mushy- how to tighten? LCA078 1999 to 2016 Super Duty 4 08-11-2012 01:25 PM
Racing a 6.0 vs. modded 7.3... input PLEASE!!! V10haulin' 6.0L Power Stroke Diesel 42 05-14-2011 02:37 PM
1989 F-350 Dually Diesel 5sp. wilson_cattle_co 1987 - 1996 F150 & Larger F-Series Trucks 3 05-10-2007 08:42 AM
V10 or diesel for our needs??? pilot4x41 1999 to 2016 Super Duty 37 02-09-2007 08:52 PM
Tags
10, 1987, 1999, 73, conversion, diesel, engine, f250, ford, forum, forums, swap, troubleshooting, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
